Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Noise after clutch install.
Old Mar 3, 2015 | 05:02 AM
RaceProfessor's Avatar
Default Noise after clutch install.
Good morning, I've been searching and was unable to find a resolve so I'm praying you guys can help me.
I just replaced my clutch in my 2009 FA5 with an Exedy Stage 1 08806 with a matching HF02 chromoly flywheel.
Ever since the clutch was installed, at 50+mph, there is a pronounce metallic grinding/rattling noise coming from the trans/clutch area.
It only occurs while coasting, if the clutch or throttle is applied it completely dissapates. I've read everything from throw out bearing, pilot bearing to input shaft bearing being the culprit and I'm on the brink of going insane, the noise is unbearable.
The noise wasn't present prior to the clutch install, I replaced it merely because it was starting to show symptoms of slippage. The technician that performed the work hasn't a clue so I'm looking to the expertise of the 8thCivic members.
The rattling/grinding noise ONLY presents itself while coasting and completely silence itself the moment you press the clutch or thottle. Thank you for any much needed help gentlemen.
Old Mar 6, 2015 | 04:39 AM
SpeedRacerEX-R's Avatar
Default Re: Noise after clutch install.
Is it a sprung hub disc?
Old Mar 6, 2015 | 09:59 AM
Yes sir.
Old Mar 7, 2015 | 06:53 AM
Any chance that one of the springs on the hub, have come off the disc? I've seen that happen before...
black96
29
Jan 3, 2016 08:34 PM
Nick Kozeski
Sep 2, 2015 02:18 PM
RaceProfessor
Transmission & Drivetrain
Mar 7, 2015 10:24 PM
AlaskaREX
May 30, 2013 06:53 PM
Buckshot
Nov 6, 2002 05:29 PM
