NEED HELP! 07 Si Wheel Bearing replacement
Hello there peeps, i am in search of a DIY or tutorial on changing out and replacing my front wheel bearings for a 07 civic si, Preferably the left side because that is the one that is damaged at the moment. Also which ones are the best bang for the buck :D please and thank you all in advance
You can get the bearing alone but to replace it you need to disassemble the hub from the knuckle and this usually renders the hub unusable.
z6hatchboy
Feb 6, 2009 06:31 PM
pcorad
Nov 7, 2001 04:55 PM
pcorad
Nov 7, 2001 08:41 AM
