Need Help Installing B16 into '89 Civic
Old Nov 3, 2002 | 03:52 PM
crazyfiz's Avatar
Default Need Help Installing B16 into '89 Civic
I have a complete B16A1 swap Ecu, Tranny, Engine, The whole thing. I used the SI Wiring harness b/c the engine plugs diddnt match i ran the lines for knock and v-tec and rvery thing that needed to be added to that ecu all is done and done right. I am getting a engine code of 8 TDC I dont know what to do the car has no spark. Help I need to get tghis fixed ASAP. I also tried to use the SI ecu and The SI distributor DIDDNT WORK!!
Old Nov 3, 2002 | 03:58 PM
Danbu$'s Avatar
Default Re: Need Help Installing B16 into '89 Civic (crazyfiz)
Lots of thread on how to swap this motor
use the SEARCH button
or try http://www.hasport.com
good luck
Old Nov 3, 2002 | 05:34 PM
Malgerus's Avatar
http://www.geocities.com/chipman_13/ecu.html#VSS
tells you a list of codes and the solutions to fix them.
crxdummy
Mar 20, 2007 10:54 AM
stockcivic103
Jul 26, 2006 08:03 AM
progress
May 4, 2006 09:41 PM
shownogo78
Feb 1, 2006 11:39 AM
tlieu88
Dec 7, 2001 10:04 PM
