97 civic driverside pop when u turn right
Old Feb 28, 2015 | 04:25 PM
borrego805's Avatar
10 Year Member
Default 97 civic driverside pop when u turn right
hey guys i have a 97 civic and it pops every time i turn to the right. i have already changed my upper ball joint (skunk2 camber kit) and my lower ball joint (i banged it in with a hammer) and today i replced the axle hoping it would stop but it didnt. can any one help me out???????
Old Feb 28, 2015 | 04:52 PM
Jimi Hondrix's Avatar
Default Re: 97 civic driverside pop when u turn right
Might be the shock spring binding. Do you have coilovers or stock shock/springs?
Old Feb 28, 2015 | 05:06 PM
Former User's Avatar
Maybe the other axle is bad.
Old Feb 28, 2015 | 06:18 PM
borrego805's Avatar
10 Year Member
well i have koni yellows with ground control coilover but they havent given me any problems it all started when i installed my skunk2 camber kits
Old Mar 1, 2015 | 04:06 AM
Have you tried re-torquing the upper control arm castle nut? If that nut is loose or the bushing between the upper control arm/knuckle assembly is worn it could make a popping sound. Being that it's a new camber kit the bushing shouldn't have issues but, worth taking a second look.
Also, re-torque the control arm's strut tower nuts.
Here's a vid of installation in case you need it... also, grow a beard like that dude's in the video and your cool points will rise:
matryx
Jul 25, 2008 09:14 PM
redej878
Suspension & Brakes
Feb 16, 2008 05:03 AM
tonysaur
Dec 25, 2005 02:05 AM
DaChoZn1
May 15, 2005 07:57 PM
