Central locking damaged
I took the negative wire to wire lock and unlock but the driver's side has one more but I have two schemes the alarm that a normal book and take two negative engines but I called the ECU and the other scheme will be equal to mercedes that and that k have to do because the driver's side has no engine so the other doors ... which I find strange and that before mounting the alarm worked and after the ride crashed
the doors were working fine before i insttaled the alarm but after installing the alarm on the 4 doors the drivers door doesnt open , it does work manually with the key but the other 3 passager doors stay close they only open and close with the alarm remote control . i connect 2 negative wires to the engine but the car got a control unit on the drivers door, the drivers door got 3 wires and the other passegers door got only 2 wires
That is what we describe as the "ecu for the doors"
It is on the drivers side door, remove the interior door panel and it is a blue box. You can check your power readings from there using a volt meter, or volt gauge.
You are looking for the "door lock control module".
I already tried to measure the multimeter but just show me current to a wireless n now know if I should have some more current ...
Aftermarket locks, did you follow the diagram, are you using the switches that came with the kit or are you trying to implement the oem switches to work with this kit?
edit:
ok so this is the alarm diagram, do you have factory central locking units or not?
edit:
yes tou connecting to the coming of manufactures... i try the other way but only closes the 3 passengers doors and the driver still doesnt close and now makes a wierd noise in the ECU what i keep doing rong do i need to buy some closing motor to thr drivers door? ..i also try connect the wires directly to the fuses box on the panel but whend I connect one wire made a huge spark and I was afraid to burn something in the car..
