IL ALL MOTOR BUILT **RUST FREE** WHITE RS INTEGRA
SELLING MY INTEGRA BEFORE I MOVE OUT IN A MONTH OR 2
*****CAR IS COMPLETELY RUST FREE******
ORIGINAL QUARTER PANELS- OEM MOLDINDING - NO BONDO- OEM PAINT
CAR IS FROM THE SOUTH
MOTOR HAS JUST BEEN BUILT /INSTALLED AND BY TUNED BY Mikey at pro function ONLY 850 MILES ON it-
NEED TO SELL MOVING OUT- buying new car.
BEFORE HAVING MOTOR re Built IT WAS IN A CIVIC
WITH 243WHP AND 153WTQ on E85 - and was 219whp on 93 pump gas
NOW HAS CUSTOM PORTED INTAKE MANI- and a NEW NON DENTED HEADER AND FRESH REBUILD CAR WAS JUST TUNED AND
PUT DOWN ON 93 PUMP GAS 236WHP AND 167 WTQ
WITH RETUNE AND E85 SHOULD BE 250WHP
I HAVE WELL OVER 7K INTO PARTS AND 4K INTO LABOR AND REBUILD and car cost me $3500-
BLOCK
B18c Gsr block
Golden eagle sleeve installed by golden eagle
Gsr crank with all new bearings
All ARP bolts/studs
Golden eagle rods
Cp 85mm pistons 12:8 compression
New T-belt and water pump
All new gaskets
TYPE R OIL PUMP
hi end header
HEAD
B16 head
Skunk 2 pro series valve springs
Skunk 2 pro 2 cams
Skunk 2 pro series cam gears
Ferrea valves
custom ported by Mikey form pro function == Skunk 2 intake manifold with hondata gasket
Skunk 2 70mm throttle body
3 inch intake pipe and Blox velocity stack
New cap and rotor and wires
New blackworks racing radiator and fan
Hondata s300
Excedy stage 2 clutch and 8 lbs flywheel with lsd trans
Just installed a catch can to a vented valve cover
FULL SKUNK 2 PRO SERIES 70MM EXHAUST WITH MAGNAFLOW STOCK LOOKING MUFFLER
SUSPENSION
D2 coil overs
Omni power lower control arms
skunk 2 camber kit
New rotors and hawk pads all around
15 inch black rpf1 rep. wheels
205/50r15 hankook winter tires-
205/50r15 Bridgestone re11a tires brand new JUST INSTALLED
HAS GSR INTEGRA LEATHER SEATS NO RIPS-
HAS SPARCO CHRONO RACING SEAT
jdm REPLICA TYPE R FRONT LIP
jdm style steering wheel
EXTRA PARTS NOT INSTALLED
BLOX AND BUDDY CLUB SHIFT *****.
ANOTHER BLACK DASH
2 WHITE FRONT FENDERS-
PROBLEMS-
RADIO ANTENNA NEED TO BE FIXED OR REPLACED
drivers side gator axle boot has 1in size rip. have replacement will install if not sold
dents on fenders and little on drivers door and faded paint
IF YOUR GOING TO OFFER A TRADE - I WILL ONLY TAKE A MOSTLY STOCK CAR - LIKE A HONDA S2000- SUBARU WRX- ACURA RSX TYPE S- ACURA TSX- ACURA TL- OR SUV LIKE CRV
no low ballers pls - WILL BE IGNORED
P.S NO JOY RIDES-MUST HAVE CASH ON HAND -
PRICE WILL BE $5800 obo will aslo trade for 125+cc dirt/pit bike plus cash
BLOCK
B18c Gsr block
All ARP bolts/studs
Golden eagle rods
All new gaskets
TYPE R OIL PUMP
hi end header
HEAD
B16 head
Skunk 2 pro 2 cams
Ferrea valves
Hondata s300
SUSPENSION
D2 coil overs
skunk 2 camber kit
ANOTHER BLACK DASH
PROBLEMS-
YEA - COULD GO E85 BUT ON FIRST MOTOR BUILD ONLY HAD SMALL INCREASE IN HP AND THERE WASN'T TOO MANY GAS STATIONS THAT HAD IT.
swaytec360
Sep 21, 2005 07:03 AM
