Odd Stereo Issue .
Just recently my stereo out of nowhere stopped working and yes i checked everything and nothing was bad, so just today it turned on by itself but only if my headlights (both parking and low beams) are on. A long time ago one of the of the constant wires was burned off, so I had to improvise by rerouting it to the under hood fuse box where the radio fuse is. I also notice the leds in my stereo face kept dimming on and off like I had too much power being drawn in, so I am trying to figure this out while it is like 0 degrees outside and there is snow tomorrow. Any input will be appreciated while I investigate this mystery. Thank you in advance.
96 accord lx
96 accord lx
Well when I first read this I thought for sure it had to do with the illumination circuit. The radio has a wire set aside for the illumination of your display (so you can have the brightness match between your dash/cluster lights and the radio's display automatically). I'd say you either have a failing radio that is causing a short to ground or power internally or you have another resistance issue in either your re-routed constant or the illumination circuit. Were there any other dimming lights or issues?
nope just the radio dimming flashing issue. My headlights and cluster are unaffected, so I think I will plug in previous stereo to see if it has any of the same issues to rule out possibilities.
_Cyclone_
Jul 17, 2005 08:06 AM
