95 accord not shifting out of park.
Old Feb 26, 2015 | 04:07 PM
tapjac50's Avatar
Default 95 accord not shifting out of park.
95 accord wagon won't shift out of park and windows will not work nor gauges in dash. Brake lights work, replaced vss, still no power at fuses for windows. Any suggestions please.
Old Feb 27, 2015 | 07:29 AM
coolswimmerjon's Avatar
Default Re: 95 accord not shifting out of park.
For the issue shifting out of park:
Are you not able to physically move the gear select lever out of park or does it not shift into gear when selecting drive or reverse?
If the gear selector does not move the shifter lock that is released when you press the brake might not be working. You should be able to push a car key into the hole next to the selector to manually release the lock and shift into gear. The lock only prevents changes from Park into other gears and does not interfere with shifts between gears or into Park.
Old Feb 28, 2015 | 04:53 AM
Lost Again's Avatar
Check the #1 10 amp fuse in the under dash fuse box......almost everything you list as "not working" is traced back to this fuse
Old Mar 1, 2015 | 11:21 AM
MAD_MIKE's Avatar
MM Gruppe B
^This.
It powers the ICU, no ICU no go
Old Mar 3, 2015 | 04:57 PM
Lost Again's Avatar
Mike....this looks like another where we will never know the answer
Old Mar 4, 2015 | 12:40 AM
MAD_MIKE's Avatar
MM Gruppe B
I'm keeping the hope alive, not sure this is a one hit wonder just yet.
Old Mar 7, 2015 | 06:20 AM
Lost Again's Avatar
I call one hit wonder now
Kind of like one of these The Greg Kihn Band - The Breakup Song
tapjac50
Feb 27, 2015 03:13 PM
bks84
17
Sep 19, 2011 06:40 AM
RiCoVelas
Honda Civic (2006 - 2015)
Oct 4, 2009 07:15 AM
Ryan31
Jun 24, 2009 04:52 PM
Bitpicker1011
Aug 26, 2004 10:15 AM
