92 prelude battery charging issue
Old Feb 26, 2015 | 10:56 AM
ginjaninja717's Avatar
Default 92 prelude battery charging issue
Is it possible that I bought a batter that is to big for the stock alternator to charge?
Old Feb 26, 2015 | 11:59 AM
holmesnmanny's Avatar
No. What is your issue ?
Old Feb 26, 2015 | 12:05 PM
Default Re: 92 prelude battery charging issue
I had bought a new battery and the car would start no problem for a couple weeks and theN all the sudden. The new battery is dead. Now I can't drive it right now so I've been starting it every other day and moving the parking spots. I have jumped the battery and let it run for 15-20 min. As soon as I turned the car off the battery was still dead.
Old Feb 26, 2015 | 01:38 PM
Sounds like the alternator isnt charging the battery. Get a multimeter. Start the car and test for voltage. Write down the voltage reading. Turn on the headlights. Again note what voltage you're seeing. Tell us what voltage you are seeing. Also, does the charging system light ever come on ?
Old Feb 26, 2015 | 02:51 PM
The charging light not come on and I'll have to go buy one of those meters. I'll post what I find out soon! Thank.
Old Feb 26, 2015 | 03:37 PM
1991_crxsi's Avatar
Sometimes people overlook this. If one of the connections at the battery terminal are fault/not making a solid connection to the post then the battery will not properly charge.
Old Feb 27, 2015 | 09:59 AM
Yes thats true. However that wont cause the alternator itself not to charge.
Old Feb 27, 2015 | 05:09 PM
1991_crxsi's Avatar
Correct, it will just prevent the battery from being charged by the alternator.
busha61067
Feb 10, 2010 04:54 PM
Vt3c_eg
Jul 15, 2008 03:16 PM
justseeingifitistaken
13
Feb 17, 2008 12:32 AM
ef9one6
Apr 17, 2007 07:31 PM
smash fascism
Dec 22, 2005 09:13 PM
