Turbo for ITR
Old Nov 3, 2002 | 02:36 PM
vtec.dc2's Avatar
Default Turbo for ITR
I did search, read through every one of results
(for daily driven car)
Currently stock motor with 370cc injectors-hondata, icebox, jdm4-1 header, 63.5mm cat&exhaust, 8.5 lb flywheel
My options
1. head port-n-polish, cam gears (maybe some stage 1 camshafts), toda header....... with this i'd like to get to ~200whp.
or
2. For about same price I could run custom turbo kit, hondata/boost option and make more than 200whp with low boost.
If I'm to go with #1, that would be the end of mods, i would not want cams or any other mods. reasons - reliability and somewhat of increased maintanance.
Running turbo would yeld more hp, and if i'm to keep it low boost - it should last longer and be more reliable for daily driving? - am i getting this right?
[Modified by vtec.dc2, 6:37 PM 11/3/2002]
Old Nov 3, 2002 | 02:39 PM
Ferrell's Avatar
Default Re: Turbo for ITR (vtec.dc2)
200 whp with stage 1 cams? i dont think this would be the end of the mods for 200whp.
i believe n/a would be more reliable than boost.
Old Nov 3, 2002 | 02:58 PM
yellow blur's Avatar
Default Re: Turbo for ITR (Ferrell)
you'd be surprised.
Old Nov 3, 2002 | 03:05 PM
Rob :190:'s Avatar
Default Re: Turbo for ITR (yellow blur)
you'd be surprised.
exactly, i'd say if the turbo was installed and tuned properly, it can be just as reliable as an NA setup. Just cause its NA doesnt mean its reliable, any time you mess with the motor (cams, etc) you risk the chance of install error or product failure.
Old Nov 3, 2002 | 03:06 PM
vtec.dc2's Avatar
thats what i used to think.. but there seem to be a number of type r's running mid 200's or more with no problem (or as far as i know)..
hearing so many complaints about agressive cams snapping or tearing everytning around them, low boost for same money is starting to make more sence to me... but opinions are welcome
Old Nov 3, 2002 | 03:13 PM
Shark Tank's Avatar
its all up to you. either way when you play with aftermarket components some error may come into play. i dont think na is more reliable than turbo or vice versa. give you an example, i just put my head back together and put it back on the block, car never blew smoke at all, and now it seems i have problems with the rings in cylinder 3. just all of a sudden, by the way, i am na and making 215whp, your setup will not yield 200whp, just an fyi for you.
Old Nov 3, 2002 | 03:16 PM
Rob :190:'s Avatar
Default Re: Turbo for ITR (CART fan)
how do you know that? there have been plenty of dyno's on here that have similar hp with similar mods.
Old Nov 3, 2002 | 03:18 PM
Fuuma0083's Avatar
Default Re: Turbo for ITR (Rob :190:)
all about TUNING
Old Nov 3, 2002 | 03:24 PM
vtec.dc2's Avatar
i just estimated.. maybe mid 90's...
currently 176
lets say port&polish 5-10hp, toda header 3-5hp, stage 1 cams 5hp,= 13-20hp
i'd rather not make it into debate - it would just be the most i'd do as N/A
Old Nov 3, 2002 | 03:26 PM
Shark Tank's Avatar
well stock bottom end would probably have something to do with not making 200whp, but hey it is all about tuning and thats my .02. good luck with what ever route you may choose.
Old Nov 3, 2002 | 06:24 PM
MiraiZ's Avatar
Not quite the same price dude...a 'reliable' turbo setup on an ITR is going to cost MUCH more
[Modified by MiraiZ, 12:25 PM 11/4/2002]
Old Nov 4, 2002 | 04:39 AM
AccrdATK's Avatar
New User
Default Re: Turbo for ITR (MiraiZ)
hmm... i was thinkin of goin NA at first... recently have been lookin in to go turbo.. but now.. ive finally decided to save up and go NA
Old Nov 4, 2002 | 04:40 AM
AccrdATK's Avatar
New User
Default Re: Turbo for ITR (CoreysTypeR)
o and you say stage 1 cams.. what cams are you referring to
Old Nov 4, 2002 | 07:19 AM
Rob :190:'s Avatar
probably the mild cams, Toda A's, skunk 1s, etc.
Old Nov 4, 2002 | 07:24 AM
Reid's Avatar
Global Moderator
True, but a properly done turbo setup is the fizzle.
Old Nov 4, 2002 | 08:03 AM
vtec.dc2's Avatar
yep, one of these
Old Nov 4, 2002 | 09:28 AM
vtec.dc2's Avatar
i think i'm gonna change my direction towards boost.
would like to end up around 230whp. So maybe 3-4psi to get there with hondata s200/boost option
Really don't know where to start...
If anyone has any suggestions, information, links - let me know
thanks
Old Nov 4, 2002 | 09:43 AM
Smitdog's Avatar
Boost!!
Old Nov 4, 2002 | 09:54 AM
Rob :190:'s Avatar
3-4 psi? PLease, run 6psi, it can be done just as easily....
Old Nov 4, 2002 | 10:06 AM
vtec.dc2's Avatar
well.. more hp - why not..
my reason for running lower boost - i might not tax the motor as much? - unless it makes no differnce running 6psi vs 3-4psi.. then i might reconsider
Old Nov 4, 2002 | 10:11 AM
Back in Black's Avatar
Rather OG
People have run double digits on a stock R motor with no problems, though I personally think boosting our motors is retarded.
Jason-
who thinks the money can buy a lot more power elsewhere...
Old Nov 4, 2002 | 04:00 PM
B18CXr's Avatar
us retarded boosted C5 owners enjoy rolling all forms of street cars all the while laughing at dumbphuckheads that think boosting is a waste off $$$.
1 Bar on a C5 is off the fizzle!!!!!
Old Nov 4, 2002 | 04:25 PM
ZygSpeed's Avatar
Make up your mind ahead of time and stick to it.
Otherwise it may never end.
[Modified by Zygspeed, 4:19 PM 11/7/2002]
Old Nov 4, 2002 | 07:17 PM
vtec.dc2's Avatar
Default Re: Turbo for ITR (Zygspeed)
well.. my mind is made up that i will be going FI route... although i got no clue on what to look for in custom kit, other than i'll be using hondata for managment.. anyone can help out?
Old Nov 4, 2002 | 08:00 PM
MiraiZ's Avatar
research...and have a lot of money ready...that's all I gotta say
