automatic transmission
Old Feb 23, 2015 | 05:29 AM
bigtony23's Avatar
Default automatic transmission
I have an auto accord..when I turn the car on, the D4 gear in the cluster starts to blink and stays blinking when yhe car is in use,, what does this mean? How do I turn this off?
Old Feb 23, 2015 | 09:07 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: automatic transmission
There is a stored trouble code, you will need to retrieve the code and fix the problem.
What year is your Accord?
Old Feb 23, 2015 | 10:18 AM
bigtony23's Avatar
1992
Old Feb 23, 2015 | 11:32 AM
MAD_MIKE's Avatar
MM Gruppe B
Passenger side kick panel.
Look above it, there should be a two wire blue connector either attached to the wire harness or floating in space.
Use a wire(metal paperclip)to jump the connector.
Turn ignition to II(ON)
Watch the D4 light blinks, record the code produced, long blinks are multiples of 10, shorter ones are multiples of 1.
Report back here with code(s) for further diagnostic aid.
prelude_93vtec
Jun 17, 2019 09:31 PM
Elijah Herndon
May 22, 2017 03:16 PM
jarrodscot
May 18, 2010 01:30 PM
DOHCon15s
Sep 30, 2003 06:38 AM
b18civic
Feb 18, 2002 03:58 AM
