d16y7 - Rocker Arm Push Rods
Push rods? Uh, your engine doesn't use push rods. You might want to pull your valve cover off and actually look at what's going on in there - this isn't American muscle. Cam lobe touches rocker arm, rocker arm touches valve stem. End of system.
I was just about to say the same thing. Pushrods in a d16? huh?
I said that because I wasn't sure. I have a loud ticking noise and I can't figure it out, also I just took the valve cover off and it has milky looking oil in it. Is this the Head gasket or cracked head?
Or the car has been sitting for years and there's condensation built up. But hey, I'm just being optimistic.
The loud ticking is most likely poorly set valve lash, though.
