Car shakes
Old Feb 22, 2015 | 05:41 PM
jmanuel's Avatar
Default Car shakes
When istart car if I let idle in place all is fine but if I start to turn steering wheel car begins to shake ? Could this be the psp or?
Old Feb 22, 2015 | 05:42 PM
jmanuel's Avatar
Default Re: Car shakes
Car has 151k
Old Feb 22, 2015 | 11:07 PM
MAD_MIKE's Avatar
MM Gruppe B
That is the engine being loaded, IIRC the ECM should compensate. Might need to look into troubleshooting.
Old Feb 23, 2015 | 12:59 AM
jmanuel's Avatar
Fasure I'll try looking up some troubleshooting tips for this type of problem cause once wheel is turned its a constant hard shake and pretty annoying but thanks for the reply
Old Feb 23, 2015 | 03:27 AM
holmesnmanny's Avatar
The idle is going to drop slightly when you turn the wheel at idle as the ecu compensates for the load. Normal.
Old Feb 23, 2015 | 08:19 PM
jmanuel's Avatar
Well yeah iknow thats normal but hard shaking isn't normal. Hopefully its nothing too serious or costly I'll just try to figure it out solo before itry taking it in to get checked out
Old Feb 24, 2015 | 04:25 AM
masospaghetti's Avatar
Is it shaking because the idle speed drops? Or does it feel like it's the actual movement of the rack that's related to the shaking?
You sure you're using Honda PSF? The universal stuff is not OK for your Honda.
Ash983
Honda Civic (2001 - 2005)
34
Oct 4, 2024 11:12 AM
NACvicSi
Jun 13, 2011 05:04 AM
scythe88
Jun 14, 2010 10:13 AM
TheLastSpartan
Jul 8, 2005 10:02 PM
mitch529
Feb 21, 2003 11:38 AM
