Civic no start
Old Feb 22, 2015 | 11:58 AM
Whiteonblackej's Avatar
Default Civic no start
95 civic 1.5 started the other day just fine. I had been having some idle issues so I decided I was gona clean the Iacv. I've done this before and it clears the idle but I guess it got clogged up again. So I cleaned it and put it back on . Waited about a hour and it started up but was running bad . Then it shut off now . Now I can't get it to run at all it will turn over but will no start up . Could the Iacv just go out ?
Old Feb 22, 2015 | 01:13 PM
09chaplak's Avatar
Loves Tossing Salad
Default Re: Civic no start
IACV won't cause a no start condition, just a rough idle. Any CEL's? Hit up this link for some info on no start diagnostics https://honda-tech.com/honda-civic-d...2A%2A-1992733/
Old Feb 22, 2015 | 01:56 PM
It's not throwing any codes off and ok I'll check it out
Old Feb 22, 2015 | 02:01 PM
Former User's Avatar
During the IACV work, did you unplug the spark plug wires or mess with the ignition system?
Old Feb 22, 2015 | 02:06 PM
Only thing I did was unbolt the 2 screws and sprayed cleaner in it . I didn't take it fully off when I cleaned it . I waited a while then just screwed it back in
Old Feb 22, 2015 | 02:10 PM
Maybe a bolus of cleaning fluid got sucked into the cylinders, causing a loss of compression. Remove the plugs and add a teaspoon of oil to each cylinder and try again.
If that doesn't help, then move to the fundamentals - Does the fuel pump prime? Is there bright white spark at all 4
Old Feb 22, 2015 | 02:18 PM
Gonna try that out now and yea the fuel pump primes right up and I'm Gona check the spark out now also
Old Feb 22, 2015 | 02:22 PM
Click the Spark link in my signature.
Old Feb 22, 2015 | 02:39 PM
Putting oil in the cylinders didn't help . Gona check the spark next
Old Feb 22, 2015 | 02:54 PM
Also my spark plugs are black not the greyish white color I can post a photo of them if that could be a issue . And I have to get that spark tester tomorrow
Old Feb 22, 2015 | 02:58 PM
You just need a spare spark plug.
Old Feb 22, 2015 | 03:00 PM
so just follow the spark test with a spare plug ?
Old Feb 22, 2015 | 03:09 PM
Yes. Did you click the Spark link?
Old Feb 22, 2015 | 03:20 PM
Yea I did . And I'll have to check it in the am I don't have any spare plugs at the moment.
Old Feb 22, 2015 | 04:22 PM
Anyway to test it with a spare spark plug ?
Old Feb 22, 2015 | 04:24 PM
Yes. Dude, please read my Spark link.
Old Feb 22, 2015 | 04:28 PM
I'm sorry I meant without a spare plug
Old Feb 22, 2015 | 05:02 PM
Maybe with a screwdriver I just don't want to get shocked
Old Feb 23, 2015 | 05:38 AM
09chaplak's Avatar
Loves Tossing Salad
No, do not test spark without a spare plug or spark tester.
Old Feb 23, 2015 | 12:18 PM
Just check the spark it was like a orange spark not a white spark at all
Old Feb 23, 2015 | 12:22 PM
Ohm test the coil - see FAQs sticky.
Old Feb 23, 2015 | 01:34 PM
will try that soon as i get home
Old Feb 23, 2015 | 06:56 PM
hey so if it turns out to be the ignition coil would it be best to change the whole distributor?
Old Feb 24, 2015 | 03:14 PM
So just take the ignition could out of the car and use a multi meter ? I don't underdtand to do after that . Like testing the ohms
Old Feb 24, 2015 | 05:41 PM
Ok I took the cool off of testing and I noticed the little wire looks burnt off and I didn't realize it till I got it off and don't know if that could be the problem
