evap control canister vent shut valve: Q
1998 Honda Civic EX Coupe
I removed my evap vent shut valve and blew through one side of the valve and I discovered that the air blew through without resistance. is my evap vent valve faulty or is the valve only shut when energized?
Vent valve or purge valve?
I believe the vent valve is shut, but when tank pressure is high it'll open, so blowing will likely open it. Purge valve is closed.
Are you having a problem fuelling? If that's the case, inspect vent filter(if equipped) and canister for liquid fuel.
thanks for answering my question, I was hoping that it was normally closed so I could just buy a new one and b done with the issue.
