99 civic IACV gone bad?
Old Feb 19, 2015 | 08:43 AM
jdmoscar703's Avatar
Default 99 civic IACV gone bad?
99 Honda civic lx. I'm doing a mini me swap, Using a 00 head and 98 intake manifold. Well my question is could my IACV go bad? I've cleaned it did the 2plug conversion. For some reason it makes a annoying beeping sound its sounds louder when I put on the air intake on, is antifreeze suppose to come out when taking off the IACV because mines isn't?
Old Feb 19, 2015 | 11:11 AM
Default Re: 99 civic IACV gone bad?
Its not allowing me to rev over 3500rpm
Old Feb 19, 2015 | 06:22 PM
09chaplak's Avatar
Loves Tossing Salad
Any CEL's? The IACV won't be the culprit in the 3500 rev limit. Yes, there are two hoses in the back of the intake for coolant to pass through the IACV. When you unplug these are you not getting any coolant dripping out?
Old Feb 19, 2015 | 06:29 PM
slomofo's Avatar
GDD Member
What's making the beeping sound, the engine or the IACV?
Is your timing belt installed properly?
Old Feb 19, 2015 | 07:20 PM
CEL code P0335 (CKP SENSOR) I replaced it with an aftermarket CKP sensor I bought at my local advance auto parts store and now car isent going over 3500rpm. Yes, the annoying noise is coming from the IACV
Old Feb 19, 2015 | 07:36 PM
Former User's Avatar
The CKP sensor is inside the distributor housing. Is that what you replaced?
Old Feb 19, 2015 | 08:25 PM
The sensor I replaced was the Crankshaft position sensor which is right next to the crankshaft pulley.
Old Feb 20, 2015 | 04:59 AM
09chaplak's Avatar
Loves Tossing Salad
That's the CFK, crank fluctuation sensor. Did you clear the code and is it still popping up? Position sensor is located within the distributor.
Old Feb 20, 2015 | 05:03 AM
This^. You replaced a sensor that has nothing to do with P0335.
Old Feb 20, 2015 | 09:00 AM
I got a new distributor about 2-3 months ago. Is it failing on me already is that the reason why car isent reving over 3500rpm?
Old Feb 20, 2015 | 09:52 AM
09chaplak's Avatar
Loves Tossing Salad
Could be, where'd you get the distributor from?
Old Feb 20, 2015 | 10:09 AM
tamboo's Avatar
10 Year Member
Advanced Ignition Troubleshooting - Team Integra Forums - Team Integra
Old Feb 20, 2015 | 11:27 AM
Got the distributor at my local advance auto parts store.
Old Feb 20, 2015 | 11:30 AM
Is P0335 or any other CEL codes currently thrown? If so, post them.
Old Feb 20, 2015 | 02:16 PM
CEL codes p0108 manifold absolute pressure sensor & p0113 intake temperature
Old Feb 20, 2015 | 03:11 PM
Reset ECU. Run engine. Check whether both codes repeat.
Old Feb 22, 2015 | 07:55 AM
Reset my Ecu. Scanned and got 4 CEL codes p0335 crankshaft position sensor, p0336 crankshaft position range/performance, p0505 IACV, & p0108 manifold absolute pressure sensor.
Old Feb 22, 2015 | 08:07 AM
P0335 and P0336 - Use a multimeter to Ohm test the CKP sensor in the distributor.
P0505 - Clean the IACV.
P0108 - Make sure you haven't swapped any sensor connectors and then voltage and Ohm test the three wires in the MAP sensor connector. If all is fine, then replace the MAP sensor. Then go from there.
Old Feb 22, 2015 | 12:05 PM
Ok, so far I've removed the distributor cap for some reason I can't find the srew for the rotor in the distributor. I've cranked it to rotate the rotor and I find no screw. Any suggestions on how to remove the distributor rotor?
Old Feb 22, 2015 | 01:10 PM
09chaplak's Avatar
Loves Tossing Salad
Some of them don't have one, try just pulling the rotor off.
Old Feb 22, 2015 | 02:15 PM
Or remove the entire distributor and carefully cut off the rotor with a Dremel tool. Install new rotor with screw.
Old Feb 25, 2015 | 03:16 PM
Luckily I was able to exchange my distributor and got a new one. So far car runs pretty well the only problem is that it sometimes idles a bit but it's not that bad do to the long Y7 throttle body cable and CEL. I reset the ECU Droved it for a good 20miles. CEL popped back up scanned it got code P0505, I cleaned the IACV put it back on still doing the same thing. I did the 2 plug conversion for the IACV, just wanted to make sure the yellow/black wire is connected to the top wire on the 2 wire plug correct?
Old Feb 25, 2015 | 03:28 PM
HondaPartsHero's Avatar
Technical Hero
You are using a Manual P2P ECU correct?
Old Feb 25, 2015 | 03:31 PM
Technical Hero
Old Feb 25, 2015 | 03:38 PM
P0505 is never caused by an electrical problem in the IACV circuit.
