00 civic Hatchback dx - metal to metal sound
Good Evening everyone!
I was wondering if anyone can give me some ideas on what the problem can be on my car, maybe you have experienced it before.
The car has a metal to metal sound from the rear right when you are turning left and when you get certain bumps. It sounds terrible. I changed the rear hub w/ bearing, and the rear upper control arm. Still has the same noise. I was wondering if maybe the rear hub wasn't tightened properly? I am very confused with this sound. I have put the car on the lift and nothing is rubbing, the wheels do not touch any part of the fender. The only thing I have recently changed has been the suspension. Not sure if that can be something causing this problem. Any help would be greatly appreciated, going crazy with this!
-Tommy
-Tommy
Is the car lowered? Is it rear drum or disc in the rear? If it sounds like metal on metal then chances it is. You should be able to find the wear mark somewhere.
If it started after the suspension change it has to be that 99%.. New or used? Coilovers or sleeves over stock struts? Tire rubbing the inner wheel well?
If it goes away on the lift again it must be suspension. Putting it on the lift unloads the suspension.. you need to preload the control arm and then play with the tire.
The car is lowered about 2 1/2 inches from stock. Its on Truhart fully adjustable coilovers. It is rear drum I have looked all over and have not been able to find any marks anywhere. It happened after the suspension change. I was thinking maybe its a blown shock. Tire not touching any where as the fenders were pulled out in order to avoid tire touching anywhere. I can not create the sound while the car is on the lift. They were purchased brand new. I was thinking of swapping out the shock and putting the one I had on it before to see if the sound continues?
Thank you for the replies.
I also thought about the exhaust hitting but when I checked it doesn't look like it is that. I'm going to change the shock in a couple of hours and will let you guys know what happens. Anyone think it can be the hub that wasn't tightened correctly?
You can't tell until you drive over something that will make the exhaust hit it, a bump. The exhaust isn't really bolted onto the car, just has rubber hangers holding it up.
-Tommy
-Tommy
This complete situation just sucks! And I did not get to switch shocks. Will do it tomorrow afternoon and let you guys knows what happens.
theguy22
30
Oct 28, 2013 07:45 AM
purple98ek
Apr 15, 2007 12:25 PM
chadmasterc
Jan 18, 2007 04:05 PM
jdmztrane
Jan 21, 2006 08:08 AM
