Check engine light blinks TWICE need HELP ASAP
Old Nov 3, 2002 | 12:45 PM
AprilzWarrior's Avatar
Default Check engine light blinks TWICE need HELP ASAP
I need help right away help would be greatly appreciated, its a 95 Prelude SI 2.3ltr At a dead stop the engine idle drops then it shuts down entirely. My Best guess is the Throttle Position Sensor. PLEASE ANY IDEAS......
Thanks
AprilzWarrior
Old Nov 3, 2002 | 12:51 PM
PrecisionH23a's Avatar
Default Re: Check engine light blinks TWICE need HELP ASAP (AprilzWarrior)
did you pull the code yet?
Old Nov 3, 2002 | 12:52 PM
Default Re: Check engine light blinks TWICE need HELP ASAP (GudeH23a)
Umm I got in, Started it, wait till it warms up then pow I the light comes on, 1 long blink, then 2 short blinks thats all Ive done so far....
Aprilz
Old Nov 3, 2002 | 01:37 PM
satan_srv's Avatar
http://www.hondaprelude.to/main_checkengine.html
Code 12
EGR Valve Lift Sensor
- Lift Insifficient Detected
- High Voltage
Probable cause:
EGR Valve (with lift sensor)
EGR valve lift sensor circuit
EGR control solenoid valve
EGR control solenoid valve circuit
EGR line
ECM (ecu)
Old Nov 3, 2002 | 02:04 PM
Default Re: Check engine light blinks TWICE need HELP ASAP (satan_srv)
Would this not allow the engine to idle and shut down ?
Old Nov 4, 2002 | 03:05 PM
Ok Ive looked into the Throttle Position Sensor and the Stealor wants to sell me the entire Throttle Body Assembly for over 500... WTF ?? Could this entire problem be the EGR ??? Please help !!!!
Ive also done a complete tune up, Plugs. Wires. Cap. Rotor. PCV valve. Fuel Filter.
Please Please Please Help !!
Aprilz
Old Nov 4, 2002 | 03:09 PM
oldirt3277's Avatar
New User
let me know I also have kinda same prob irratic idle unless all electrical devices are on then when coolant fan turns off it acts up again I am going to change the tps on the back of the tbody that's my last option I beleive
Old Nov 4, 2002 | 03:39 PM
Default Re: Check engine light blinks TWICE need HELP ASAP (oldirt3277)
Guess what man, if you plan on changing the TPS, the Stealor says the entre Throttle Body must be changed as well !!!!
Old Nov 4, 2002 | 04:28 PM
satan_srv's Avatar
That's complete bullshit. You take a dremel and cut slits into the rivets and then you can remove the TPS with a screwdriver. Whoever this Stealor person is they are a tool and know nothing about cars, you give this person money?
Anyways, Why would it be your TPS if you're getting an EGR code? They are not related.
[Modified by satan_srv, 8:29 PM 11/4/2002]
Old Nov 4, 2002 | 05:19 PM
DsITR's Avatar
Notice how he calls him "the stealor" (spelled differently, i know)...HELLO sounds shady to me.
potatointegra01
Jun 24, 2015 12:52 PM
gnxpro24
45
Apr 22, 2011 07:12 AM
cprlover
Dec 7, 2010 04:35 PM
