Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Airbag light 2005 Accord
Old Feb 16, 2015 | 06:30 PM
Lou_EM1's Avatar
Default Airbag light 2005 Accord
I bought an 05 Accord LX a few weeks ago and after a few days this airbag light comes on and have been on since. When I start the car it will come on and off for a second and then stays on until I turn off the ignition.
Old Feb 16, 2015 | 11:27 PM
VeeSykkz's Avatar
Default Re: Airbag light 2005 Accord
my 2006 has the same light on. Its for a bad drivers seat airbag sensor in mine. Likely similar on yours
Old Feb 19, 2015 | 07:47 PM
B18c1vicrx's Avatar
That is your SRS light, go have the code pulled and see what it reads. Anything seat belt related is covered free of charge at the dealership unless the car has been wrecked, I mention this because often times Hondas set off SRS codes for a faulty seat belt buckle tensioners, but not always.
Old Feb 23, 2015 | 03:19 PM
Scottwax's Avatar
There is a TSB/recall on that issue, the problem is the buckle.
Try doing this:
Buckle up before turning your car on. If that keeps the airbag light from coming on, the problem is the seat belt buckle.
Old Feb 25, 2015 | 06:26 AM
Lou_EM1's Avatar
Try doing this:
Thanks, but the same issue occurs.
I just noticed that my seat belt retraction system is very weak on both sides of my coupe, especially the passenger side. I recently noticed this when my mom would bang the male belt clip against the door sill while attempting to close the door. I'm going to go to Honda new week and attempt a free inspection and replacement of the seat belt since that mechanism should be 'covered for the useful life of the vehicle' per this link http://techinfo.honda.com/rjanisis/p...303O00300A.pdf
But I want to make sure I know the code(s) first since I don't want to be charged a diagnostic fee. How do I pull codes myself on a 05 LX? Is there a good DIY?
Thanks
Old Feb 26, 2015 | 06:45 PM
BLKFLSH's Avatar
This link should help you get the codes. Good luck
DIY: SRS Codes and reading them. - Club RSX Message Board
Cpt Marvel
14
Dec 18, 2012 12:59 PM
vectorvtec73
Dec 29, 2010 08:00 AM
vroomboom
Honda Civic (2001 - 2005)
Jun 3, 2008 12:31 PM
work9to5
Nov 10, 2007 08:39 PM
