STUCK...
ok so I just replaced upper and lower ball joints, thinking that it was the cause for my wobbling..after 2 days trouble shooting and repairing. got all buttoned back up, too realize it didn't fix ****...at real low speeds the wobbling is so bad that it feels like the wheel is gonna just break off. first though was wheel bearing, after I had the knuckle off the car, the wheel bearing was fine, noticed the ball joints where fuuuucked..so replaced those. and didn't fix..is there anyone that can add some insight about this problem..im at a loss
Could be a busted belt in the tire. Sometimes hard to spot but will walk it all over the dang place like a drunk walking out of the bar. Possible bent wheel.
stick with it, you will get it.
ok ill take a look at the tire..its odd because I feel the damage of whatever it is on the right side. the right tire has real good tread, but ill look also at the rim..my front driver tire is worn bad on outside edges real bad, ive had a recent alignment..could tie rods cause this by chance? thank you for your input bro I appreciate it
The one worn out real bad it probably transferring it's motion into the rack and causing it to just feel like it's the other side. If you can see belts, the tire is done and can shed the tread anytime it wants.
chaplainpace
Jun 27, 2017 10:32 AM
