Ek coupe cant stop overheating!please help
Old Feb 14, 2015 | 02:24 PM
Gustavo's EK's Avatar
Icon3 Ek coupe cant stop overheating!please help
whats up everyone i am new to the forum and did my research but i couldnt find and answer to my problem. i drive a 97 civic coupe dx model d16y7 motor.
My car would over heat after 15+ mins of driving. At first i didnt have a thermostat and had a stock radiator. i then replaced the radiator and made the cooling fan run automatically 24/7. id take the car to OC from IE without a problem and ahad a relaxed idle.
BROTHER DROVE THE CAR WITH RADIATOR CAP OFF TO THE SIDE.
NOW i cant even get to TACO BELL without the car overheating. and when im at idle the car seems to vibrate on and off.
This time it has a new thermostat and bled the cooling system. when i bled the system bubbles only came out when i reved the engine. FAN was running 24/7. I stopped after 30 mintutes. idk if i shouldve kept going.
i went from overheating in 10 minutes from a cold start to overheating after 15 minutes of driving on the highway. i would get an idle surge from time to time.
p.s im not sure if the head gasket is blown. im not showing white exhaust smoke,milky oil and im not losing coolant.
Should i bleed the system again?
PLEASE HELP thank you in advance and god bless.
Old Feb 14, 2015 | 03:24 PM
Default Re: Ek coupe cant stop overheating!please help
any insight or suggestions are greatly apreciated
Old Feb 14, 2015 | 07:27 PM
NotARaCist's Avatar
I never narc'd on nobody!
How exactly did you bleed the coolant? Something isn't adding up. Either you aren't fully bleeding the system, or you have a leak, or you have a damaged head gasket. Follow the following coolant bleed procedure, and buy/borrow/rent a block testing kit from your local parts store to test the head gasket.
Bleeding done right:
Put the front end of the car on jack stands (or park facing up a hill)
Remove the radiator cap
Start the car
Fill the radiator, and continue filling it until bubbles are no longer present
Let the engine run for two fan cycles after this, to verify that there are no leaks (since you have your fan hacked up, just let it run for 15 minutes after totally filling)
Turn off engine, replace radiator cap, lower car, done.
Total time in your case should be about 45 minutes to an hour.
Old Feb 14, 2015 | 07:42 PM
JarvisW's Avatar
Sol to Sol
Sounds like (edit) head may have been warped the whole time
Take the cap off, let it warm up enough to get the thermo to open, then rev the engine while watching the fluid in the radiator.
If it bubbles, you have a bad head gasket. If not, do what NAR said above.
Old Feb 15, 2015 | 03:06 PM
Oaken81's Avatar
We use those spill free funnels at work when bleeding honda cooling systems.
I would make sure there is no air in the system as well as pressure testing for leaks.
If you are still overheating after the above, i would then check for hydrocarbons in the coolant.
Old Feb 16, 2015 | 01:06 PM
thanks for the responses guys.
I bled the system again yesterday. i did it exactly how you explained it. i was able to get to work today with no overheating but did start to go over the OT point when i was parking it.
when i was bleeding the system i noticed that the cooling system will rise and a lot of air will shoot out ONLY WHEN I REVED it.
Im going to go rent the gasket leak testing tool after work.
i will let you guys know what happened. THANKS AGAIN much appreciated god bless!
Old Feb 16, 2015 | 10:40 PM
Heisenberg's Avatar
Could be broken/disintegrated water pump blade? If you use water as coolant, and hasn't replaced the water pump ever, that could be it. The need to rev the engine could have somehow allowed a bit of a flow of coolant. But come idle speed, no chance. Have your water pump inspected.
Last edited by Heisenberg; Feb 16, 2015 at 10:41 PM. Reason: if increasing the rpm helps reduce overheating, that is likely a water pump issue
Old Feb 17, 2015 | 08:01 AM
Former User's Avatar
The head gasket is blown.
Old Feb 17, 2015 | 12:36 PM
im going to get the water pump inspected along with the head gasket test.
Old Feb 17, 2015 | 12:38 PM
slomofo's Avatar
GDD Member
How much gas is in the tank?
Old Feb 17, 2015 | 12:40 PM
around half a gallon
Old Feb 17, 2015 | 12:41 PM
slomofo's Avatar
GDD Member
You should def top it off cause I heard gas prices were on the rise. Get in now while it's cheap.
Old Feb 17, 2015 | 12:44 PM
lol alright thanks
Old Feb 17, 2015 | 12:46 PM
I thought slomo was going to come through with one of his useful insights.
Old Feb 17, 2015 | 12:49 PM
haha he saved me a few bucks
Old Feb 17, 2015 | 01:02 PM
slomofo's Avatar
GDD Member
Let's just say you saved $20 in gas.
Take that $20 and boom, Fel Pro head gasket.
Take that Fel Pro head gasket, slap it in your car and boom, no more overheating.
Full tank of gas, no more overheating, and now you can hit the streets in your fully gassed up non-overheating Civic.
Old Feb 17, 2015 | 01:08 PM
Haha...slomo wins with the trap door spider maneuver.
Old Feb 17, 2015 | 01:38 PM
**** yeah. then i will be able to continue with more mods. thanks man!
edwinbaby
Honda Civic (2001 - 2005)
12
Jun 14, 2010 09:19 AM
jdmCivic925
12
Jun 18, 2006 04:58 AM
zerovandez
10
Sep 10, 2005 04:56 PM
purple98ek
Jun 26, 2005 04:38 PM
FOrSfEd
Feb 5, 2004 04:48 PM
