Help - Timing belt rubbing
Old Feb 10, 2015 | 04:18 PM
rc2904's Avatar
Default Help - Timing belt rubbing
I have a 97 civic with a d16y7. There has been a noise for a while which i have finally tracked down to being the timing belt rubbing on one of the water pump bolts. I tried taking off the tension and scooting the belt out further from it but it seems to work its way back once the car has been running. Has anyone else had this issue or have any ideas what to do about it ?
Old Feb 10, 2015 | 05:58 PM
JarvisW's Avatar
Sol to Sol
Default Re: Help - Timing belt rubbing
Is that a stock waterpump? If not it may not be the correct casting and makes the bolt "proud".
Old Feb 11, 2015 | 11:06 AM
09chaplak's Avatar
Loves Tossing Salad
Belt should be able to clear everything with relative ease. Is the bolt loose? Did you see if it's torqued down to spec?
WiedemannC
Dec 6, 2010 12:35 PM
B!^A@
Aug 14, 2006 09:24 PM
trevor72
Jun 7, 2006 09:55 AM
precord96
Mar 4, 2005 05:51 PM
RedRyda
Jul 28, 2004 06:20 PM
