95 accord trans replacement
So this weekend i replaced my trans. And everything seems to be working correct except the clutch pedal pressure, and shifting gears.
i changed the clutch also with the exedy oem replacement and it just seems to soft compared to before it was changed. We bleed the clutch till there was no more air in the line even a couple extra times to be sure.
now with the shifting gears, it goes into every gear but it is very clunky and there is like a pause before each gear. This i have no idea what it could be. Could the shift cables use adjusting? If so, how do you do that? Is it wearing anything in the trans?
Oh and its an f22b2 5spd replaced with the same trans
Also with the shifting issue i have, do you have any idea what that could be i know it was very descriptive but it seems like its got a gate to bypass before going into gear but its weird because it happens in first every time and any other gear when the car is off and i put it in a gear for lets say a hill. Could that be in the trans? That would be very disappointing. Something with the cables we didnt put back together right?
Granted you might not be interested in doing so, but my trans feels the same, and its hooked to a H22 and shifting where I...ahem, want to shift, is very difficult, and it feels very gated as well. If you run WOT from first through third, would the transmission not want to let you shift from 1-2 and 2-3?
Well, the ideal is ~ 1" of play at the end of the pedal, from full extension to feeling it firm-up. What happens if there is no play, or a negligible amount?
And accordion, if the clutch is engaged, its engaged. The issue with clutch break in is severity of engagement. I'm not suggesting shifting aggressively, rather taking it to redline at most-throttle and then quickly pushing in the clutch, and seeing if it will want to change gear. After you determine how it wants to shift, just ease the clutch back in.
It won't do anything to the new clutch if you adjust it properly. The end result is adjusting the resting position of the fork.
SlowCD5
Nov 9, 2013 02:14 PM
jdm_phunk
Feb 27, 2011 05:17 PM
