Body Repair-Drivers front wheelhouse
Old Feb 10, 2015 | 07:27 AM
danteisme's Avatar
Loved
Community Favorite
Default Body Repair-Drivers front wheelhouse
i'm no stranger when it comes to body work and painting, but i have never attempted a repair like this one before. luckily i never had to until now. i have a nasty rust hole that has expanded pretty large in the front wheelhouse. here is a pic:
the hole is in the piece i have circled in red, i seen that honda still sells this piece new. how much of a PITA is it to take this off the car and either fix it off the car or replace it with a new one? my previous body works was really limited to just the outside panels, i've never messed with something like this before.
Old Feb 10, 2015 | 11:36 AM
jlk16188's Avatar
Default Re: Body Repair-Drivers front wheelhouse
This piece is a real mother ***** to get off and replace. It is probably best to remove the rust and treat it.
You dont show a picture of the actual hole so i cant tell you much else
Old Feb 10, 2015 | 11:51 AM
danteisme's Avatar
Loved
Community Favorite
the hole is huge now, probably not able to be repaired. at least not easily with this piece on the car. the hole is the entire width of that piece and probably 6 inches long. its from when i had the car slammed several years back and drving on our awesome PA road salt covered roads in the winter
Old Feb 10, 2015 | 11:56 AM
jlk16188's Avatar
take a pic. I work near you in Murrysville. I bet I could patch it up
Old Feb 10, 2015 | 11:58 AM
danteisme's Avatar
Loved
Community Favorite
no kidding? where do you work at? you can pm if you dont want to air it out on the public forum lol
Old Feb 15, 2015 | 12:21 PM
94EG8's Avatar
Seagull Management
Basically get a good spotweld bit, drill out all the spot welds and then separate the piece (an air chisel works best but a cold chisel and a hammer will work) Then clean everything up really well with a flap disc or fiber wheel. Weld the new piece in, grind your welds down, prime with epoxy primer, seal the seams with seam sealer, done.
It's not a hard job, just time consuming.
Old Mar 30, 2015 | 07:15 PM
mlab's Avatar
Got the exact same problem.
1. I want to save money and take them off myself (spot weld cutter, chisel, grinder, etc.). Can I drive without them on the car to get to an auto body shop and have new ones welded on or will any bump make something bend or crack?
2. Do you know of a online shop where I could get a good deal on these?
Part numbers are : 60614S01A00ZZ and 60714S01A00ZZ
Thanks!
Old Mar 31, 2015 | 05:30 AM
danteisme's Avatar
Loved
Community Favorite
i've always ordered my parts from acuraoemparts.com. i still havent fixed this yet. i may just try to make repairs with what i have and weld in new metal once i cut all the rusted stuff out.
Old Feb 7, 2021 | 04:11 AM
Lawrence Wong's Avatar
Auto Body Shop uses advanced technology to reveal the shadows of the dent, which guides the technician’s tool placement and allows them to restore the damaged area to its original position.
Beau Gotti
Jan 3, 2009 10:19 AM
allmotorRyan
Paint and Body
Jul 11, 2008 12:23 PM
-[95cxhatch]-
14
Feb 14, 2006 08:31 AM
88 rex
Welding / Fabrication
15
Feb 16, 2005 01:25 PM
GroundZer0 336
Aug 13, 2003 01:12 AM
