dohc on a sohc f20b6
Old Feb 7, 2015 | 07:24 AM
marky2014's Avatar
Default dohc on a sohc f20b6
Can you put a DOHC head on the f20b6 with the vtec, any help and info appreciated
Old Feb 7, 2015 | 07:36 AM
NerfGunner420's Avatar
Default Re: dohc on a sohc f20b6
yes you can. not worth it. low compression engine. oil leaks. jb weld some oil galleries on the head. so not worth it
and if you did any research you would of found this out
Old Feb 7, 2015 | 08:34 AM
GhostAccord's Avatar
So much easier just to do the complete engine swap!
Remember, you gotta to pay to play and there really is no replacement for displacement!
Old Feb 7, 2015 | 05:57 PM
MAD_MIKE's Avatar
MM Gruppe B
F20B6? English Accord?
You can put a an F/H DOHC head on the block, but it would be a bit more work than simply using an F20B(DOHC) from a CF Accord. And you should be able to stay in your engine/tax bracket.
Logo
Aug 13, 2018 10:01 AM
jimakazi
Oct 12, 2016 08:52 PM
t_boneshacone
Aug 10, 2008 09:23 AM
dc2chris
Jul 17, 2006 02:35 PM
Novice
Jun 12, 2001 01:32 AM
