h22 swap into 88-91 crx
Old Nov 3, 2002 | 09:06 AM
bottledcrx's Avatar
Default h22 swap into 88-91 crx
i was looking to get some info on swapping a h22 into my crx and couldn't find anything specific on here.. so if someone could give me some links or info.... i would appericate it ....thanks
Old Nov 3, 2002 | 11:52 AM
MysteryWagon's Avatar
Default Re: h22 swap into 88-91 crx (bottledcrx)
Placeracing.com makes a kit, with axles, mounts that still require work and front cross member.
NOTE: the H22's weight and torque have been nown to bend the rear crossmember back from the power, plus it is understeer form hell.
but check out the kit, their site might be down right now.
there is also alot of engine bay space making like hammering. alot
[Modified by MysteryWagon, 4:53 PM 11/3/2002]
Old Nov 3, 2002 | 12:11 PM
USDM 4G VTEC's Avatar
Default Re: h22 swap into 88-91 crx (MysteryWagon)
have u ever driven a 4G H22???
i guess not
i have driven one once...
the car doesnt understeer too much like everybody claims it does... of course it will if u go 50+ on a curve, or dont have good tires and /or suspension.... its called momentum pulling u... i have never heard about crossmembers being twisted,,,,
the only thing i recomend tis having the whole suspension worked.. i mean good bushings, struts, springs, schocks, etc etc.... stock suspension sucks for that power....
Old Nov 3, 2002 | 12:58 PM
xtrafastcivic's Avatar
i don't think place ever made this kit...
Old Nov 3, 2002 | 01:21 PM
Default Re: h22 swap into 88-91 crx (JDM EF9)
calm your tic tacs down my friend, I am talking about fast turning. Personally I like to take turns fast. It is difficult unless you have alot of money to do so with a Hseries motor. AKA good suspension. when you have the money to do all that good for you. I was just saying with a h22a in a stock ride.
Did I ever emply, with full suspension set up.......uuuhhh. NO!!! so we are on the same boat with stock suspension sucking for the power the engine makes and yes plaeracing does have a kit. I believe it still requires welding and the kit is hosted on Jdmhondaparts.com and Placeracing.com.
keep your jollys in your pants and quit sweating over posts if you don't read them fully.
and by the way I have witnessed masive work on a H22a crx getting worked on because the engine was torquing the crossmember back. and this was on slicks which probably had alot to do with it.
I did not say anything about it being on slicks because most people that would do a sawp like that most likely would want to run on something a little more sticky.
keep the peace
Justin
Old Nov 3, 2002 | 01:26 PM
http://www.jdmhondaparts.com/frameset.htm
-go to engine components
-Boltin kits "placeracing"
that is the kit, everything is seprate which comes for the swap.
I swear people get testy, and by the way driving one once does not give you the permision to say it does not bend the crossmember, it happens over a period of launches unless the guy is planning on launching everyone in a while all for him.
later
Old Nov 3, 2002 | 01:28 PM
dont worry man
i never take it personally.. theres no point of that on the net..
anyways i was just letting everybody know....
even with stock suspension we can do 55mph turn and the car will slide like a ****... we just saying we need some good suspension in order to compensate for the power.. i love h22's they are nice well desgined engines.... i lvoe curves too.. but i know how fast to go... even a A6 pushing good hp will have bad understeer...
yes the slicks sounds like the factor on that crx....
and dont worry i still got my piece!
Old Nov 3, 2002 | 01:51 PM
oops.. i've seen h22a's in crx 2 to be exact and it looked like a regular joe wouldn't be able to do it... a lot of modifications.....
Old Nov 3, 2002 | 05:18 PM
playerhatersdream!'s Avatar
Default Re: h22 swap into 88-91 crx (XtraFastCRX)
point blank.it can be done.and it is very drivable.just takes a lot of work.man i hate it when people shoot down h22 swaps in a ef.seriosly eg's with h22's dont really get harrassed its only h22's in a ef.whats the diff there both cars going to have a lot of understeer.it is a great swap bro.im not going to hate just because i cant afford to do it.im a honda crazed filipino just loving the scene.
Old Nov 17, 2002 | 04:45 PM
KS-R's Avatar
Yeah... It's not exactly a bolt in affair...Lots of cutting and welding, but it's definitely worth the hard work... At least for me it was.
Old Nov 17, 2002 | 06:07 PM
fastwanabe's Avatar
Default Re: h22 swap into 88-91 crx (playerhatersdream!)
the UNDERSTEER issue has been exagerated quite a bit Ive never had a problem, BTW I roll on a stock suspention.
Old Nov 17, 2002 | 06:39 PM
hOOch's Avatar
Default Re: h22 swap into 88-91 crx (fastwanabe)
you have to take out power-steering and A/C for a H-22 rite? Thats 200 hp also? Wouldn't a b18 with a turbo be faster than h22 w.o one?
Old Nov 17, 2002 | 08:03 PM
slywfbpsi's Avatar
Default Re: h22 swap into 88-91 crx (hOOch)
are you able to use the hydro tranny that comes with the h22?
Old Nov 17, 2002 | 08:22 PM
KS-R's Avatar
Default Re: h22 swap into 88-91 crx (slywfbpsi)
You have to.. I don't think there are any cable H series trannies.. But you'll need to convert the clutch to hydro... but Place Racing has a kit that can use your clutch cable to activate the hydro clutch.... You can modify your stock clutch pedals to use hydro.. That's what I had to do with my car.
Old Nov 17, 2002 | 08:57 PM
slywfbpsi's Avatar
Default Re: h22 swap into 88-91 crx (KS-R)
k, thanks
Old Nov 18, 2002 | 05:56 AM
WuShu's Avatar
New User
do a search for h22 in this forum.
Old Nov 19, 2002 | 10:59 AM
hOOch's Avatar
Default Re: h22 swap into 88-91 crx (HondaCRX)
Old Nov 19, 2002 | 12:19 PM
crxrookie's Avatar
there is not a lot of information on this page about h-22 swaps, because they are pretty uncommon compared to the more popular b-16 and zc. if you go to pretty much any site that sells the motors tho, they will give information. i have never seen an h-22 powered crx, but from what i've read on the internet it is a very hard swap. it is a pain in the *** to make it fit.
Old Nov 19, 2002 | 10:31 PM
sporkcrx's Avatar
Default Re: h22 swap into 88-91 crx (crxrookie)
who cares about the little bit of understeer when you have all that power!
94prelude1488
31
Jul 18, 2012 05:35 AM
ekkkk20
34
Mar 26, 2008 10:13 AM
iNDiO
Jan 27, 2008 03:16 PM
ExplicitSpeed
Nov 13, 2004 10:09 PM
Turbo-Si
Jan 21, 2002 03:51 PM
