Mid-Atlantic (Sales) VA, DC, and MD
MD: 92 Built Turbo Integra GSR
Old Feb 3, 2015 | 04:09 PM
WannaRun??'s Avatar
Default MD: 92 Built Turbo Integra GSR
FOR SALE/FOR TRADE
VIN: JH4DB2387NS000628
The car is a clean title 1992 Acura Integra GSR. There is 293,XXX miles on the chassis and 10,XXX miles on the built motor and trans. Car runs and drives strong. I have owned the car since it has had 254,XXX miles on it. I daily drove the car for 2 years when I decided to have the motor built and after the build process I decided to purchase a newer daily driver. Because I now have a daily I rarely drive the Integra, about once or twice a week. I love the car but I am ready to build something else.
READ THIS PART: Before you read any further I would like to go over the BAD.
No the car does not have the B17 in it anymore. The car is a 23year old Honda, with this comes random noises like squeaking and rattles, leaking of water in the trunk and passenger floor board(from blower fan), and most importantly RUST. This car has rust at both rear wheel wells and some by the driver side molding. If you love Honda's then these little things are a part of the character. Also, the car does not have power steering or air conditioning, it's a racecar.
Now, onto the good stuff. I do have receipts for most things.
Motor(2.0L):
-84mm AEBS Sleeved B18B Block
-LS Crankshaft
-9.7:1 CP Pistons
-Manley H-beam Rods
-ACL Complete Race Bearing Kit
-ARP Rod Bolts
-ARP Headstuds
-JE Pro Seal Headgasket
-ATI Street Crank Damper
-B17 Head
-Supertech Flat Face Valves
-Supertech Valvesprings
-Supertech Retainers
-Supertech Valve Seals
-Supertech Valve Seats
-Supertech Valve Locks
-Skunk2 Tuner 1 Cams
-Skunk2 Cam Gears
-Golden Eagle Sandwich Plate Kit
-Hondata Heat Shield Gasket
-Edelbrock Victor X Intake Manifold
-S90 70mm Throttle Body
Turbo Set-up:
-Precision 6265 T4 1.15a/r Divided Housing(rebuilt with less than 3000miles)
-Full-Race Divided T4 Top-mount manifold
-Treadstone TR12 Intercooler
-(2) 46mm Precision Wastegates
-Tial 50mm BOV
-2.5" hot side intercooler pipping
-3" cold side intercooler pipping
-Hondata 4 BAR MAP sensor
-Hondata electronic boost controller
-Custom 3" downpipe
-Thermal R&D 3" Turbo Exhaust
Transmission:
-YS1 GSR Cable Transmission
-Syncrotech Carbon Synchros
-Mfactory LSD
-Competition Clutch Stage 5 With Extreme Pressure Plate
-Competition Clutch 12.5lbs Flywheel
Fuel System:
-Full-Blown Twin Pump Fuel Hanger
-(2) Full-Blown 340 Fuel Pumps
-Full-Blown Fuel Rail
-Aeromotive Fuel Pressure Regulator
-Full-Blown Fuel Filter
-Custom Fuel Feed and Return Lines and Fittings
-ID1600 Injectors
Suspension:
-Function & Form Type 1 Coilovers
Random:
-Full-Race Traction Bar
-no name Short Shifter
-no name front & rear strut bar
-no name c pillar bar
-hood dampeners
-Hondata Traction Control
Wheels/Tires:
-15x6.5 Rota Attacks
-(2) 205/50/15 All-seasons
-(2) 195/55/14 All-seasons
-(2) Lenso's with used slick mounted
Resistance:
-(Front) Brembo blank rotors
-(Rear) Drilled and Slotted Rotors
-New Rear Brake Calipers
-Goodridge SS Brake Lines
Interior:
-PWJDM Shift ****
-Jensen Double-Din Head-Unit
-Innovate MTX-L Wideband
-AEM Boost Gauge
-AEM Oil Pressure Gauge
Exterior:
-Type-R style front lip
-Retrofitted Projector Headlights with 55w 5k bulbs
-45% Window Tint
Im sure there are many things I have forgot so feel free to ask.
The motor was built by Charm City Tuning and most recently tuned by Innovative Motorworks. John Kerr was able to pull a safe 515whp 367wtq at 20psi out of the car on 93octane. With this set-up on race gas there should be zero issues making huge power.
On that same tune with the combination of the Hondata Traction Control I was able to run a 11.9 @ 133mph on ALL-SEASONS. I have yet to run the car on the slicks because I like having a streetable car and I am very happy with the 11.9.
I am posting the car unsure of what it is worth, however I will not give the car away and think $7,000 is a fair starting price. Although I have many years attachment to the car and even more money sunk into the thing I feel that this is the dollar amount I will be willing to accept and walk away from it.
As stated before if there are any other questions do not hesitate to ask and I will gladly answer them.
Text me at 717four3four0718 or message me for any further information
If for some reason you cannot view the attached pictures, the craigslist ad is here: 92 Built Turbo Integra GSR
Old Apr 14, 2015 | 09:24 AM
WannaRun??'s Avatar
Default Re: MD: 92 Built Turbo Integra GSR
Bump! Considering a part-out
Old Apr 20, 2015 | 05:10 PM
WannaRun??'s Avatar
Ttt
dkeb1993
Jul 9, 2016 10:51 AM
WannaRun??
Apr 20, 2015 05:11 PM
99SlammedCivic
Oct 25, 2014 08:57 AM
99SlammedCivic
Texas -OK -LA (Sales)
28
May 9, 2014 06:11 PM
cquence
Northwest (Sales)
20
Aug 14, 2011 12:54 PM
