Hello, Hope someone can help me out here. I'm doing a JDM B16A swap with a S4XA automatic Trans and a P2T-J91 ECU into a 2000 Honda Civic EX. I got everything working besides the fuel pump and the rpm's aren't working. The main thing I wanna fix is the fuel pump. I hear the main relay for the fuel pump click on but the fuel pump doesn't prime or turn on. I ran a direct wire to it and it works and the car starts. As for the rmp's the wire harness on the driver side strut tower that goes into the car has only one plug the the engine wire harness has two plugs. The bigger plug plugs right in but the smaller one has nowhere to plug into. I'm also looking for a kick down cable. Can anyone help me out PLZ?
This project is for the wife.
2000 Honda Civic EX strut tower plug that goes into the interior.
The two plugs from the engine harness
Automatic Transmission
ECU
Reason: Forgot something
And therein lies your problem. The B16A is OBD0 or OBD1. Your chassis is OBD2B. An OBD0/OBD1 engine harness is not going to be compatible with an OBD2B engine harness. You'll need to start with an OBD2B Civic engine harness, and work from there.
Actually the engine and wire harness are obd2. Everything plugged up just fine I just have an extra plug by the driver side strut tower. I can turn the car on with the fuel pump wired directly and it's fine. Do you think a obd2b to obd2a conversion harness would work?
1997 was the last year that had kickdown cables. You an grab a kickdown cable from the Acura dealer for a 94-97 Integra RS/LS/GS, it'll fit.
Contact hasport and ask them for an OBD2A to OBD2B jumper harness for an automatic transmission.
Unrelated, but curious, did the transmission, ECU, wiring, and engine come as a complete swap?
Then it isn't a B16A harness, since the B16A was only OBD0/1. So what exactly did that harness come out of?
Dafuq are you talking about? This is the dumbest thing I've ever heard.
