Power windows/sunroof/windshield Wipers stopped working 95 civic coupe
Old Jan 29, 2015 | 01:39 AM
RickyDayz's Avatar
Default Power windows/sunroof/windshield Wipers stopped working 95 civic coupe
So the tittle pretty much says it all. And I have searched it and found many post about this but non with a straight answer so I'm hoping I'll get some more luck by asking myself. I was told it could be a faulty ground connection but I've looking under my dash and steering wheel and have not found any connection to ground what's so ever. Any help would Be really appreciated. My power windows don't go down at all. My windshield wipers don't move & my sunroof won't open.
Old Jan 29, 2015 | 03:31 AM
janz3n's Avatar
Default Re: Power windows/sunroof/windshield Wipers stopped working 95 civic coupe
Have you checked fuses?
Old Jan 29, 2015 | 10:17 AM
RickyDayz's Avatar
Yes I have. All the fuses are working perfectly. Any other ideas please ?
Old Jan 29, 2015 | 10:33 AM
angrysmileyface's Avatar
Did you check underhood fuses as well. These 3 circuits all have fuse 41 and fuse 39 under the hood in common. (I checked the helms). They also share the same ground point of G201/G401
They also have fuse 14 in the main panel. Have you checked it with a continuity tester/ohm meter instead of a visual inspection
Old Jan 29, 2015 | 10:43 AM
RickyDayz's Avatar
I did check both under dash and under hood fuses both visual inspection & with a continuity tester. They all seem to be in good condition. I was told to check the ground connection but I was unable to find where that is.
Old Jan 29, 2015 | 10:44 AM
Check this thread.
https://honda-tech.com/honda-civic-d...oblem-2615438/
Old Jan 29, 2015 | 11:00 AM
RickyDayz's Avatar
This was really helpful thank you !! I shall try it and see if it fixes the problem .!
Old Jan 29, 2015 | 11:15 AM
RickyDayz's Avatar
I can't seem to find either the G201 nor the G401 any help ?
Old Jan 29, 2015 | 02:55 PM
delsolintegra's Avatar
On my 94 del sol I had to replace the Integrated control unit part number 38600-SR3-A130-M1. I got one at the junkyard it's about the size of a pack of cigarettes and it's mounted to the back of the under dash fuse box. (pry it off). It controls the windshield wipers and a few other electrical systems.
Like a main relay it can short out from heat and moisture.
Old Jan 29, 2015 | 09:14 PM
RickyDayz's Avatar
Well I checked all those fuses and those are all good under the dash & the things it controls work perfectly fine with the exception of the sun roof. I still haven't figured how to get it too work
Old Jan 30, 2015 | 04:21 AM
Former User's Avatar
20A dash fuse #14 is likely blown.
Old Jan 30, 2015 | 04:57 AM
With the moonroof, if you manually crank it open, can you use the close button to make it work? The moonroof uses 2 different fuses for opening and closing. To manually crank it open, there is a plastic tab you turn and pop free and then using the allen key that came with the car, crank it open a little bit, and see if the close button pushes it back. Other wise, try replacing fuse 14 with a known good and possibly the ones under the hood with a known good.
Old Jan 30, 2015 | 05:37 PM
Better yet, voltage test fuse. This will tell you whether the fuse gets voltage from the ignition switch and whether it is blown. Click the Test Fuses link in my signature.
Old Feb 1, 2015 | 11:46 PM
RickyDayz's Avatar
Well Thank you for All the help. I finally got everything to work again perfectly. I got help from my friend who has access to very descriptive wiring diagrams of my car due to his school & I was able to figure out the Missing ground Connection. And got that fixed myself & I can finally enjoy my sunroof once again . Thanks again for all your help . Much appreciated.
Old Aug 19, 2016 | 10:24 AM
94 Civic Si's Avatar
Premium Member
Loved
Community Favorite
No more "Test Fuse" link in sig?
Old Aug 19, 2016 | 10:50 AM
[QUOTE=94 Civic Si;51025939]No more "Test Fuse" link in sig?[/QUOTE
https://honda-tech.com/forums/honda-...fuses-3079359/
Please stop bumping old threads.
vteck1ck
10
Jan 21, 2010 06:21 AM
EF9*Hottie
Audio / Security / Video
Nov 8, 2007 06:55 AM
ScottieA
Jan 23, 2006 12:01 PM
19codyscivic94
Dec 19, 2005 04:57 PM
