2000 Civic EX overheating
I have a 2000 Civic EX just recently put in a D16Y7 from a 99 Civic LX. I swapped my intake manifold from my Y8 Motor.
The other day I got it running and it started to overheat within 10 mins or so of running. I felt the top and bottom hoses and they were cold. Also the radiator probably only took as much as it could of antifreeze. So I suspected thermostat.
Tonight I replaced the thermostat. Car ran for 20 mins plus Burping the system. Never had heat inside the car and the Open/ Close Valve is working. Then all a sudden with me having my funnel in the radiator it started boiling out so to speak of the funnel and the temp gauge said it was of temp. I shut the car off.
So then I topped the radiator off once again, took hardly anything. Ran the car for 5 mins and it shot up to 3/4 on the temp gauge. And this is where I don't know what's going on. Keep in mind its 22 degrees outside. The fan never kicked on, but I know all that works from the previous motor I had in it.
Any help would be great.
Did you burp the system with the engine level (on ramps or jack-stands) ? Some recommend that as the proper way of burping, never tried it myself. Any leaks or squeaks coming from water pump? Check the radiator fan fuse?... even though it;s 22 degrees outside the radiator needs the fan to pull air through it to cool it.
Radiator fan fuse is good, I replaced the radiator fan anyways b/c I have one laying around. The car is sitting level on its wheels. I am burping the system as I mentioned above with the funnel in the top of the radiator and just adding antifreeze little by little.
Oh and I magically have heat now. Still overheating though.
300k
23
Nov 4, 2015 08:44 PM
omerfar23
27
Aug 25, 2013 03:51 PM
