Need quick answer bypassing heater core on B20b EG!
Doing a b20b swap , car has no heater core or anything under dash . I was planning to remove thermo housing and weld the one port shut .. Is this correct in doing so ? I will leave one hose from intake manifold to thermostat housing and weld other shut ? Just making sure this is correct.
Thanks guys !
Thanks guys !
Why wouldn't you just use a U pipe on the rubber hoses that would normally connect to the firewall heater core metal pipes.
That way the option to add the core in later is still open?
Not exactly sure what you mean .. The thermostat housing has 2 ports .. One hose goes from one port to the intake manifold .. So what exactly do I do with the 2nd port ? Sorry if this is a dumb question but I thought Welding that other one shut would be a solution . Car is not going to have heat back in it
Granted this is from the stock EG/EH motor but should be relatively the same on the B20B I would think. Stock motor has three ports. You say you only have two. But I'm also counting the port to the radiator itself.
Loop it, instead of hooking up to a heater core that is not there..
Attachment 388156
93grayeg
Jan 30, 2015 03:49 PM
cubanteg16
Sep 3, 2009 10:38 PM
