catalytic converter on 2000 civic
Old Jan 26, 2015 | 04:33 PM
The Neutron's Avatar
Default catalytic converter on 2000 civic
Hi i have a 2000 honda civic. Im located in California so smog rules here are pretty strict. If i buy a universal cat that doesnt have the o2 sensor located in the cat can i just put it after the cat?
Old Jan 26, 2015 | 05:32 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: catalytic converter on 2000 civic
Generally speaking, yes.
Old Jan 26, 2015 | 05:55 PM
EkkS's Avatar
Generally speaking yes, but if the tech finds it they can fail you because of it. Also, the cat itself must be CARB legal.
Old Jan 26, 2015 | 06:49 PM
NotARaCist's Avatar
Failing you because the secondary O2 sensor is welded in past the cat, instead of...wait, what? That makes zero sense. The bung is there. It had to be welded there. Whether it was welded in before it was installed or after shouldn't make a difference.
stacdizzle
Honda Civic (2001 - 2005)
Dec 4, 2013 10:14 AM
ftrms
May 18, 2009 10:38 PM
blackouthx
Oct 2, 2007 07:14 PM
Yokohama
Mar 22, 2003 02:53 PM
