p0740 HELP
So I recently put a JDM transmission in a 01 honda civic ex It is now throwing a code of 0740 and 0700 I know the second one is a generic code and caused by the other one. The car runs and shifts fine if the light was not on you would not know there is any issues. im thinking the lock up solenoid may be clogged foolishly i forgot to check it before putting it onto the jdm because I had to replace all sensor and solenoids before putting the jdm in any help would be appreciated
Well I got the Japanese equivalent they said it would be OK if I changed out all sensors an solenoids is there a way to check if that's the problem will a better scanner give me a more defined code?
I'm not sure if the previous transmission threw the code I'm sure it did it was shot did nothing. I did have to take the sensors n solenoids from the blown trans n put them in the JDM I'm really thinking its one of them seeming it runs and drives fine but who known yes the JDM is throwing the P740
deercanbrack
May 14, 2008 03:49 PM
