2003-2006 auto trans recall?
Im in the market looking for a 2003-2005 honda accord coupe automatic. I keep reading things here and there about the automatic transmission failing? Anyone have any issues with there transmission?
Only the V6 automatic models were recalled for the transmission. The "second gear jet kit" was installed. I don't believe there was any recall on the 4 cylinder engine models. I still have my original transmission on my 03 V6, but it's been well maintained, and not abused.
I do a drain and fill every 15,000 miles, and changed the filter (yes there is a filter you can change), a couple times now at 120k miles. Basically, change the fluid as often as you have too, to keep it looking clean and red. I use the Honda DW-1 fluid.
Definitely switch over to the new Honda DW1 fluid if you haven't already. It's a noticeable improvement over the old Z-1 ATF Honda recommended for our cars. In fact, I don't believe Z-1 is even available anymore.
My 2003 4cyl Nav. Accord went out at 174K miles. Decided to rebuild it my self and it takes a while to do. 2nd gear clutch pack was completely burned out and I have changed the fluid every 60K miles. Internal filter was dirty and the bearings were worn out on the 4 shafts.
According to the dealer the recall was just a software update. Which does nothing for the internal workings of the transmission.
Call your dealer and ask. Give him the VIN and they should be able to see if the recall if any has been completed. I have a 2006 Honda Accord LS 4 door with 107327 miles. I had a recall done recently for Drive side airbag and also they performed a recall for secondary shaft software update. I did not have any problems with my transmission.
Koko4
Jan 12, 2015 03:31 PM
J Taylor
May 16, 2010 07:17 PM
allm0torGSR
Jul 2, 2006 01:26 PM
