Honda S2000 Honda S2000
vtec solenoid thread pitch bolts HELP pic
Old Jan 24, 2015 | 09:30 AM
Arthas's Avatar
Icon2 vtec solenoid thread pitch bolts HELP pic
Hello, so I was replacing my air filter on my 04 and I noticed that the vehicle has two out of three upper vtec solenoid bolts missing, not sure how since the vehicle gets driven once a month . I wanted to see if anyone knows the exact size and thread pitch so I could go to a local hardware store and purchase two more? I called honda and they can't give me info but they said the bolts come with the whole vtec solenoid
The closest I can get I'm searching was M6 x 1.00mm x 50 . Not sure if that's correct
Thanks
Old Jan 25, 2015 | 06:28 PM
lazlong's Avatar
Default Re: vtec solenoid thread pitch bolts HELP pic
Take the one bolt you do have to the hardware store, find a nut that matches and then bolts that match that nut.
Old Jan 25, 2015 | 08:53 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
It is a 6mm x 1.00 (fine) pitch bolt... however, the thread (shank) length is not 50mm. It is more like 15-18mm in length. Take the remaining bolt and measure from under the bolt head to the end... and then buy some bolts to match. You can even get them from the dealer if you understand the part number architecture... discuss it with the local Honda parts counter staff.
Old Jan 26, 2015 | 03:21 AM
Chuck S's Avatar
Part 30 on the diagram according to my data is:
Honda Part # 95701-06050-08.
86¢ each. Ya need three (3).
-- Chuck
chasebur
Honda CR-V & Element
Jan 7, 2019 05:25 PM
j3wman
Jan 9, 2012 10:48 AM
dc101
Jul 27, 2010 07:38 PM
invisible
Welding / Fabrication
Apr 12, 2009 08:26 AM
E-Rok
Jan 26, 2004 07:59 AM
