Sat navigation disc reading problem
I have a 05 accord My sat navigation doesn't work. It says disc reading error and won't play the disc, is this just the disc or another problem? Does anyone know what's the cause???
Bazz you have to clean the little laser in the DVD receiver in the back. My accord had the same issue cleaned it with a q tip and rubbing alcohol and it has worked brand new for 2 years since then no issues. This is where I got the write up to do it.
DIY: How to fix Navi disk read errors - AcuraZine Community
Thanks tommy...i had my friend burn me a new disc copy because mine was scratched up a bit so il try the disc if that don't work il give the cleaning a shot ...il let you know how I get on....
user 3216743
Apr 28, 2006 06:44 PM
