question about fuel light
Old Jan 23, 2015 | 05:13 PM
ls1formula98's Avatar
Default question about fuel light
How far can I expect to travel when the light first comes on? The car is a 94 accord. Thanks.
Old Jan 23, 2015 | 06:30 PM
professorman's Avatar
Default Re: question about fuel light
Try not to drive too often with the gas light on. Dirt typically settles in the bottom of your gas tank, and so driving with the gas too low causes the car to pull the dirtier gas from the bottom of the tank, and can cause lots of other problems.
I wouldnt drive over 30 miles with the gas light, but I have only seen my gas light once with owning my 94 Accord since 2002.
Old Jan 23, 2015 | 06:37 PM
B20VtecVillain's Avatar
Yes most definitely change your fuel filter often if your a constant empty tank runner. Even then it will be bad for the internals of your fuel pump because it actually uses the liquid fuel in the tank to cool and lubricate itself and when you run it dry the pumps internal motor temp will undoubtedly increase and cause a shortened service life. As for mileage, it really depends on how healthy the car is and how it's tuned. In general, the light will pop on when your under apprx 2 gallons of fuel. How much under 2 gal though is anyone's guess and how far you can go on that amount will depend on many factors.
Old Jan 23, 2015 | 09:38 PM
lazlong's Avatar
Approximately 50 miles but, don't push it.
Old Jan 24, 2015 | 04:57 AM
Fitz Williams's Avatar
10 Year Member
I have never seen my light come on, but the most gas I have ever put in the tank is 14 gal. I have heard the tank will hold 17, so if the light comes on when there are 2 gal. left that would make sense. On the other hand, the light may not work.
Old Jan 27, 2015 | 07:18 AM
I have been tracking my Fuel usage since I have owned my car, however, since 2012, I have been using Gas Cubby app. The average fill up for me is around 12 gallons, sometimes 13 gallons. I have a few times with 14 gallons, and the absolute most gas I have ever put in is 14.75 gallons. I dont think I had the gas light on at that time.
Old Jan 27, 2015 | 06:53 PM
Murphy84's Avatar
I don't even let my 99 accord get under half a tank. Mostly cause there's no fuel filter in hondas from the couple years around then and the injector screens get dirty and clogged and cause misfires.
khronicboy420
Dec 24, 2008 10:18 PM
meangreenEG
Honda Fit
26
Oct 9, 2008 09:23 PM
phish4709
Mar 28, 2007 04:33 AM
weakGOODJunKieS.com
Mar 8, 2003 02:10 PM
shamoo
May 14, 2002 04:27 AM
