[Suspension] What is the cause of this? EG Hatchback
SOLVED it was the bump stop plate that was missing
Just got done putting Tein S.Tech Lowering Springs on my SHS Shocks
the rear is fine but the front has the top of the shock sticking out where it shouldn't.
This is on a 93 hatchback.
Please tell me what I did wrong and how I can fix it.
Re: [Suspension] What is the cause of this? EG Hatchback
Looking at the picture and looking at the stock strut diagram it looks like the bump stop plate and the bump stop are above the damper mounting base (plate).
Looks like the strut parts were re-assembled out of order.
The bump stop and bump stop plate must go on before the damper mounting base.
Looking at the diagram again, she's missing dust cover plate, dust cover, bump stop plate and probably the bump stop if its not on there. Those are necessary, who ever helped you with this sure as hell did not understand how parts work.
Reason: correcting sex
It is the BUMP STOP PLATE that is missing. Period. The dust cover and dust cover plate do nothing to control the damper rod. If you tried to use them WITHOUT the bump stop plate, the step in the damper-rod would punch right through the hole with the first bump in the road.
It's the bump stop plate that controls the damper in compression. It's the damper mount washer that controls the damper in rebound. The rubber bushings are there to allow the damper to pivot relative to the top hat. The dust covers simply help protect the polished rod & cylinder seals from the elements.
Yes, we know the bump stop plate is what keeps the unit from shooting through the mounting plate.
In the picture, that metal disc on top looks like the bump stop plate. But I guess from what you are saying is it's the dust cover plate and there is another metal plate (bump stop plate) that goes on of that dust cover plate but under the mounting plate.
From a post of mine. Gives a good visual.
Originally Posted by deschlong
Here is a breakout diagram of a stock Honda Civic / Acura Integra front strut.
Part terms are as follows (to help other n00bs):
A. Strut
B. Bump stop
C. Tapered bump stop washer
D. Strut dust cover
E. Dust cover top washer
F. Top hat lower bushing
G. Sleeve (allows top of strut to pass through bushings)
H. Top hat
I. Top hat upper bushing
J. Top nut washer
K. Top nut (screws on to top of strut)
L. Spring
Thanks for all the replies everyone.
I fixed this right after Ron Posted the diagram.
As always its the small things that matter the most. It was the Bump Stop Plate.
Put it back in and everything sits and works as it should. ..Easy to forget the little thing.
I recommend these tein springs to anyone looking for a decent drop and great ride quality without spending too much.
