Type of transmission fluid in 94 accord
Old Jan 22, 2015 | 01:13 PM
76 camaro car's Avatar
Default Type of transmission fluid in 94 accord
What type transmission fluid should I use in my 94 accord automatic? Thanks
Old Jan 22, 2015 | 01:23 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Type of transmission fluid in 94 accord
What does the dipstick state?
Dexron III works fine, smoother shifting than Dexron II.
Old Jan 22, 2015 | 03:25 PM
Thanks, I never thought about it being on the dipstick. Anyway,I thought the transmission fluid was supposed to be checked with the engine off. I checked it with the engine warm and running and it took 3/4 of a quart to get it to barely get in the cross hatch area. My transmission fluid looks terrible.I have always heard that if it has not been changed and you change it your transmission will tear up. How true is that?
Old Jan 22, 2015 | 05:30 PM
rockycat's Avatar
Check cold and engine off, No it will not hurt to change the tranny oil.
Old Jan 22, 2015 | 08:49 PM
holmesnmanny's Avatar
Go down to Honda and buy Honda auto transmission fluid. Its one of the few things you should ALWAYS buy from Honda.
Old Jan 23, 2015 | 02:18 AM
I hope your not supposed to check it cold with engine off,If so I probably just overfilled mine.
Old Jan 23, 2015 | 03:48 AM
Should be two lines .. one is the cold line the other is the hot line
Old Jan 23, 2015 | 04:34 AM
Fitz Williams's Avatar
10 Year Member
Carquest also sells Honda transmission fluid. In the Honda bottle. There is no difference in price, but if it's on a weekend or Carquest is closer, then it may be better to buy it there.
Old Jan 23, 2015 | 04:43 AM
Ok,I'm cool then.
Old Jan 23, 2015 | 07:13 AM
19Accord97's Avatar
Honda ATF
Please search next time. There 100's of threads on this topic. All result in fights.
philztheone
Jan 11, 2015 11:50 PM
charlescee
Nov 19, 2013 08:15 PM
paulff3
Nov 28, 2007 06:18 AM
Twixle
Mar 20, 2007 07:02 AM
drumDumber
Sep 7, 2004 06:41 AM
