No spark on D16!
Hi guys, I'm brand new here but I'm looking for some help.
I just swapped my d16z6 out for a y8 (my engine was bad and a y8 is what i could get my hands on). Anyway, I finally got it all back together after way too many hours and it fired right up. I turned it off and started it again and the idle started getting jumpy. I shut it off again and started it and it was still the same. This time I let it warm up. after running a while it died on its own. After that I realized that I had missed a couple hook ups and a vacuum line to the intake so I hooked those up and tried again. No luck, it just kept cranking. Took a plug out and I'm not getting any spark. So I check to see if I was getting current to the coil and i was. I changed the wires and the distributor cap and still nothing. I'm stumped!!! Anything I might be missing?
Easy thing first, make sure the rotor is on correctly and the spring on the coil is in place/making contact with the cap. If that checks out, test the coil and replace as necessary.
I just took the rotor off to clean it. I doubt that will make a difference but we'll see.
So.... I replaced the coil and it started right up. But just like before once it heated up it sarted to pulse the engine again. I shut it off before it died this time cause I didn't want it to blow this coil also. Any ideas what's causing it to pulse the engine when it heats up and was the coil going out related?
Is the CEL on? Does it work? How exactly did you find the "Create New Thread" button, when you couldn't find the FAQ sticky thread, which is literally inches away?
https://honda-tech.com/honda-civic-d...tions-1998336/
When you're done reading that one, read this one too. You're breaking a few of them.
https://honda-tech.com/honda-civic-d...sting-3002401/
What ECU are you using? What distributor are you using? Exactly what car are things being swapped into and out of?
Okay I didn't give a good title or specific info. Anything else I need todo differently next time? I looked over the faq and didn't find anything very helpful to my situation.
I'm working on my 95 del sol. It has the original d16z6 ecu and so it is obd1. It's all stock right now.
The check engine light came on when it started the very first time last week after the swap (d16y8) but then it went off after it died and I didn't get a chance to read it. But I'll try and start it again tomorrow and see if I can read it if it's lit up.
OK. In the future, don't just pull a plug to check spark color - that could be what fried your coil. Spark testers are cheap. Buy one. Pull the CEL code(s), and post them, and we can work from there.
Crank the engine for 25 seconds to see if it throws a CEL code. Don't turn the key off after cranking so you don't lose the CEL code. Jump the service connector to recover the code.
Are you sure you browsed the FAQs sticky? I posted a bunch of ignition system diagrams there.
I don't even know what diagrams would help me here though. Sorry I'm not trying to be lazy, I really don't know what information I'm looking for.
Okay, I think I got it fixed. I feel kinda dumb but I just didn't have enough fluid in it so it was over heating and the coil must have just happened to have gone out at the same time or somehow it caused the coil to blow. The engine is has a little but of a pulse at a low rpm (above idle) but I think that's a separate issue and I'll try and do better research so I don't all you guys time
Thank you all so much!
The ICM rarely goes out, the first would go would be the coil because that is what supplies power to the spark plugs, your coil goes bad then you see your rpm's drop to 0 and your car ain't moving then you know whats up.
egluism33
May 25, 2008 06:17 PM
