Fluid Change Interval for MTF - Manual Transmission Fluid
Old Jan 20, 2015 | 07:40 AM
professorman's Avatar
Default Fluid Change Interval for MTF - Manual Transmission Fluid
I could have sworn that my Owners Manual in my 94 Accord said to change the manual transmission fluid every 90k miles, however, the online owners manual and the service repair manual now says 30k miles for manual transmission for my 94 Accord. . Did they somehow change this?
Whats your change interval for manual transmission fluid?
I got the online Honda owners manual here.
I found this post that referenced the 90k change interval:
Originally Posted by Heat
The owner's manual in my car says to change the transmission fluid every six years or 90,000 miles under normal conditions - it should be changed at least this often.
Old Jan 20, 2015 | 01:15 PM
94 accord typeR's Avatar
Default Re: Fluid Change Interval for MTF - Manual Transmission Fluid
changing fluid clears metal shavings that will clog the trans. that's why the drain plug is magnetic.
Old Jan 20, 2015 | 05:47 PM
darnizzle8805's Avatar
The recommended service interval is 30k with the current Honda fluid. Obviously if you are racing or beating on the car daily, you should either not be using stock fluid, or be changing more frequently.
Old Jan 20, 2015 | 06:17 PM
Is it the current Honda fluid that causes the change interval to decrease from 90k mile change interval to 30k mile change interval?
Old Jan 21, 2015 | 11:44 AM
I know the currently fluid is a different formula that what was being used when your car was new, as far as what changes the service interval, I honestly couldn't tell you. Possibly because of a warranty issue.
Old Jan 21, 2015 | 11:58 AM
Its a pretty drastic difference. 90k miles, to 30k miles. Same as automatics, however manual transmission doesnt go through the intense beating as what the automatic fluid goes through.
Old Jan 23, 2015 | 08:08 AM
masospaghetti's Avatar
I think the 90k interval was for 5w-30 motor oil, which Honda previously recommended for their manual transmissions. Unlike an engine, the environment inside a transmission is not nearly as harsh, there's no fuel contamination or extreme temperature variances, basically just shearing.
The new MTF has additives that improve shift quality but these additives don't last forever. If I had to guess, the 30k interval was designed for the new MTF with these additives to ensure the shift quality remains optimal.
Old Jan 23, 2015 | 09:50 AM
Okay, that sounds like a plausible explanation. I did try 10w-30 oil once and had to change it out within 3k miles. I read up about how the old oils used to work back in 94, however the new motor oils since then do not work.
imadigitalgod
187
Apr 23, 2016 07:08 AM
Heat
Jan 13, 2015 11:35 AM
Heat
Sep 7, 2005 12:10 AM
DamonBoost
Oct 27, 2001 02:28 AM
