CB7 IGNITION NO SPARK PROBLEMS
Old Jan 19, 2015 | 03:42 AM
NWsleeperswaps's Avatar
Icon2 CB7 IGNITION NO SPARK PROBLEMS
So check this out i have a 1990 accord 5 speed. It acted like the coil went out.
It cranks but doesnt start. Has fuel but no spark.
Here's where I'm at with it:
rebuilt the distributor with new coil, ignitor, cap, and rotor.
the main relay clicks, runs the fuel pump, and clicks it off
no cel codes
gets power to coil and ignitor
this leads me to believe im looking at one of three things; either a grounding issue, a bad crank position sensor, or an issue in the wiring.
Any ideas?
Old Jan 19, 2015 | 03:47 AM
Default Re: CB7 IGNITION NO SPARK PROBLEMS
forgot to mention timing belt, engine timing, and compression are good. was running fine, now its not.
Old Nov 24, 2015 | 12:31 AM
Forgot to ever update this thread. The culprit was indeed a bad ground. It was the thermostat grounding point.
e-roc88
Nov 1, 2010 03:39 PM
thunderlips
Aug 28, 2009 01:29 PM
SkIp_Civic_Ek6
Jun 25, 2006 04:54 AM
primal cb7
May 29, 2005 09:38 AM
infinate bound
Mar 19, 2004 02:25 PM
