2000 civic si - losing antifreeze?
Old Jan 18, 2015 | 09:00 AM
skyliner34life's Avatar
Icon2 2000 civic si - losing antifreeze?
Hey guys I own a 2000 civic si with the b16a2 and I have a quick question... I might be losing antifreeze but I can't tell and I can't find it anywhere so I'm not sure ... But my question is and I don't know if civics are different from other cars, my over flow tank stays the same all the time and sometimes gets more full... If my car is on and I look at it, it will be at the same level.. Isn't it supposed to suck into the radiator when the car is on and go back when it cools down?
Last edited by skyliner34life; Jan 18, 2015 at 09:19 AM. Reason: Also I tools it somewhere and they did a "head test" and they said the head gasket tested out fine and not bad
Old Jan 18, 2015 | 11:48 AM
NotARaCist's Avatar
I never narc'd on nobody!
Default re: 2000 civic si - losing antifreeze?
Coolant can only do one of two things - leak, or burn. Go to your local parts store and buy/borrow/rent a block testing kit, and use it. It'll include instructions. That will tell you if it's being burned. As for leaking, you'll just need to get your eyeballs in there and look. Carefully inspect all of your coolant lines, as well as your thermostat housing, rear coolant tube, and water pump for leaks.
Old Jan 18, 2015 | 04:44 PM
Former User's Avatar
Default Re: 2000 civic si - losing antifreeze?
Are you losing coolant or not?
Old Jan 18, 2015 | 09:52 PM
I'm pretty sure I am but it is a slow leak and I can't tell where from
Old Jan 18, 2015 | 09:55 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
The one place you can leak coolant and not be able to visually find it, is if the heater core is leaking. If it's a small enough leak it can evaporate long before dripping to the floor and your coolant recovery tank will slowly dwindle (go low) over time until you top it up.
To answer your other question as it seems you don't have an understanding of how the coolant system works. You stated it backwards..... When the car gets warm/hot/operating temperature, the coolant/fluid expands and your coolant recovery reservoir gets fuller. Then as the car cools the fluid contracts and it sucks it back into the radiator. That's why that reservoir has a max line that is several inches down from the top. This leaves room for the expansion of the fluid without overflowing.
I hope that helps your understanding of how the system operates.
If the level of your recovery reservoir is not going down overtime and your car is not overheating, then I would say it's safe to assume your coolant system is operating normally and you are not burning or leaking coolant.
Old Jan 19, 2015 | 04:11 AM
tony_2018's Avatar
Fish Twig
I never thought about it like that, about the whole expanding thing. Interesting.
Old Jan 19, 2015 | 08:13 AM
Wow thanks a lot ... That was exactly what I was confused about and yes I do understand now. If I see fluid getting lower I will check the heater core immediately
Old Jan 19, 2015 | 10:43 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Ummmm, that's not what you were supposed to take away from this.
The heater core was just one area you can have an issue with, but is more difficult to pinpoint visually.
If your fluid is going down you pressure test and also check all hose etc for obvious signs of leaking.
Your heater core, you can smell it when you run the heat.
I was providing additional information in the event your coolant was going down and you could not find signs of an obvious leak.
Pressure testing is your best tool for finding if your coolant is leaking. Then your eyes, then your nose.
Please don't just assume it's your heater core.
There are steps you go through to test and diagnose the problem. You just don't throw labor and parts at it and hope it works.
Old Jan 19, 2015 | 11:56 AM
I understand I'm just noting that it will be the first place I look for fluid leak... One of my friends has a pressure tester so I'll start from there and I still haven't ruled out the water pump
Old Jan 19, 2015 | 12:41 PM
grumblemarc's Avatar
The Grumpiest
The pressure test is the first thing you should so. You understood nothing.
If your heater core is leaking you probably would have smelled it by now.
BlueWhale
Honda CR-V & Element
Nov 25, 2014 03:33 PM
accel
Apr 10, 2013 07:54 PM
EM1_00Si
18
Mar 15, 2012 04:13 PM
B16Power
Oct 17, 2006 11:40 AM
tampabud
Aug 23, 2003 03:57 AM
