Transmission from Japan...Fluid Type?
Old Jan 17, 2015 | 06:05 PM
Dj_Kuma's Avatar
Default Transmission from Japan...Fluid Type?
Hi,
I have a 2002 Honda Accord LX with 220,000 miles.
Recently I have been having a lot of motor problems as well as the transmission jerking really hard.
I took the motor and automatic transmission out and swapped it with a motor and transmission from Japan.
I purchased it online and got it shipped to my house.
Says motor and transmission only have 40K-50K miles on it.
I got both put back in the car this afternoon.
I need to buy fluids for it.
When I bought the transmission, all it said was:
98 02 Honda Accord Odyssey 4 Cylinder 2.3L Automatic Transmission JDM F23A MCJA
Does any one know what transmission fulid I should get for it.
Will buy it tomorrow and see if everything runs right.
Thanks!
Old Jan 17, 2015 | 06:32 PM
GhostAccord's Avatar
Default Re: Transmission from Japan...Fluid Type?
The JDM engine and trans use the same fluids as your original equipment. Honda ATF or equivalent will work.
Old May 30, 2015 | 09:32 AM
Lroc00001's Avatar
How well did the jdm work in your accord? I'm thinking of doing the same
Old May 30, 2015 | 12:02 PM
barfo's Avatar
Like GhostAccord said, it'll use the same fluids. I just had a JDM take-out engine put in my wife's 98 Accord EX a month ago since the original was consuming about 1 qt of oil every 400 miles or so. We also had a salvage tranny and new Honda clutch assembly installed, so it's practically new. The JDM engine is running great and it's not consuming oil and the oil looks clean when I check it! The engine has 59k miles on it according to the place (out in California) where my local Honda shop had it shipped from.
hotboi850
Aug 26, 2014 12:39 PM
xtremecivichb
Mar 3, 2008 12:47 PM
DaJuiCe
Oct 31, 2004 10:26 AM
NewZealand
Oct 12, 2001 01:24 AM
