C101 and C136 Connector diagrams for patchy
Old Jan 16, 2015 | 07:08 PM
Former User's Avatar
Default C101 and C136 Connector diagrams for patchy
Pin 10 in C101 may be what you're looking for:
Old Jan 16, 2015 | 07:20 PM
turbohatch96y7's Avatar
Default re: C101 and C136 Connector diagrams for patchy
ok so forget about c136 if that's for an auto
So where does the other end of that connector go? looks like it connects to c303
from that connector where in the cabin do the wires go
How did you get the pics of the connectors
Old Jan 16, 2015 | 07:23 PM
You want to know what C101 connects to? D16Y7, D16Y7, D16Y5?
See second diagram I posted.
Old Jan 16, 2015 | 07:24 PM
pin 7 (gauges)
Old Jan 16, 2015 | 07:28 PM
pin 7 (gauges)
Does this answer your question?
Old Jan 16, 2015 | 07:31 PM
96-00 Civic manual - Electrical Troubleshooting
Old Jan 16, 2015 | 07:38 PM
Default Re: C101 and C136 Connector diagrams for patchy
Old Jan 16, 2015 | 07:41 PM
leme get that pdf doe
Im redoing my engine harness and that c101 connector I re routed into my cabin to connect behind the firewall instead of the bay.
BUT im getting a voltage drop because I extended the wiring about 2 feet. I doubt this is my problem but im ruling out all possibilities before I tear into the harness again
Old Jan 16, 2015 | 07:47 PM
Nevermind you already gave me that one I haven't opened it yet brb
Old Jan 16, 2015 | 07:50 PM
well the one I have just says 96-00 manual not electrical
Old Jan 16, 2015 | 07:59 PM
It's the last chapter in the 96-00 Civic manual.
Tell me what else you need.
Old Jan 16, 2015 | 08:15 PM
pin 6 says charging sys where does that go in the cabin?
Old Jan 16, 2015 | 08:18 PM
Pin 6 of C421 on rear side of dash fuse box.
Old Jan 16, 2015 | 08:22 PM
My starter cable and power cable pins 9 and 10 are most likely my problem. So I pretty much want to know where the route from the starter switch to their end locations.
I am running k coils so I don't need pin 10 any more but will end up using it as a power source for all my gauge 12v power sources.
So knowing what fuse it ties into will also help. I need to know how much current the circuit can handle.
Whats the easiest way to navigate through the manual on a laptop? It moves up and down so slow
Old Jan 16, 2015 | 08:27 PM
Pin 10 runs to 40A fuse 42 in the hood fuse box via the ignition switch:
Old Jan 16, 2015 | 08:30 PM
Pin 9 also gets voltage from 40A fuse 42 in the hood fuse box via the ignition switch:
Old Jan 16, 2015 | 08:34 PM
I use the PDF manual's chapter tabs.
Old Jan 19, 2015 | 03:40 PM
Hello ron
Ok i need more info on one more plug
Its the green one that is attached to the engine harness and main harness its like a 30 pin plug i think
K thnx
Old Jan 19, 2015 | 03:51 PM
What year and trim?
C131?
Old Jan 19, 2015 | 06:06 PM
Yeah c131 should be it
Its a 97 hx engine
I think i found my main problem with my voltage drop.
From the wht blk wire to blk yellow wire at the ign switch i was getting 10-4 ohms of resistance
So i took it apart and found the contacts a little worn out
Old Jan 19, 2015 | 06:07 PM
But since i already took my engine harness out im going to redo it anyway
Old Jan 19, 2015 | 06:18 PM
Old Jan 19, 2015 | 06:42 PM
What does pgmi mean? What exactly do those wires do? Where do they go?
Example
20
21
22
Old Jan 19, 2015 | 06:51 PM
Example
20
21
22
It means the wire runs to the ECU or main relay.
20 --> ECU pin A16
21 --> ECU pin C8
22 --> ECU pin C6
