Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Big 3 01 Civic EX Manual?
Old Jan 16, 2015 | 06:40 PM
kaivorth's Avatar
Default Big 3 01 Civic EX Manual?
Anyone have any good pictures of the ground locations for the big 3 for my particular car? A lot of guides are old and no longer show pictures. I'll try to get pictures of my engine bay tomorrow. Hopefully this fixes some random issues with my car
I think some of my grounds are in their stock locations...so pictures would be helpful.
Old Jan 17, 2015 | 07:27 AM
slomofo's Avatar
GDD Member
Default Re: Big 3 01 Civic EX Manual?
Old Jan 17, 2015 | 09:48 AM
kaivorth's Avatar
Would
these these
work for cable end terminals? Would save me soldering, but if soldering is a must I can use
these these
Old Jan 17, 2015 | 10:26 AM
toyomatt84's Avatar
Sanji
For a ground, the first link should work just fine. If it were a positive cable on the battery, I'd aim for as strong of a connection I could make and go with soldered ends.
Old Jan 18, 2015 | 07:41 AM
kaivorth's Avatar
Bah so I have to buy both or solder them all. I'll just do the grounds first and the battery replacement cables another time.
Old Jan 18, 2015 | 04:10 PM
Former User's Avatar
What are the random issues?
Old Jan 20, 2015 | 01:47 PM
kaivorth's Avatar
VERY useful pictures. Random issues:
After turning key to "Crank" position, when it's cold out, it will not do ANYTHING for about 5 seconds. Then it will crank and turn over. Replaced the battery, my grounds are just messed up from the previous owner so I thought I'd do the cheap easy thing first.
Old Jan 20, 2015 | 03:27 PM
If you already cleaned and tightened both sides of the G1 and G2 grounds and the problem persists, then next test the ignition switch.
Old Jan 20, 2015 | 03:51 PM
kaivorth's Avatar
Yeah I'm headed to the ignition switch and the starter if the issue persists. Should be easy to diagnose at that point.
DrDenby
Jul 6, 2015 07:13 AM
MarkM01
Apr 25, 2011 05:02 AM
dgerej2
Sep 9, 2009 07:31 PM
Metal Head
Audio / Security / Video
Mar 15, 2009 07:21 AM
drjondurst
Mar 30, 2003 07:16 PM
