check engine light not illuminating at startup
Old Jan 16, 2015 | 02:29 PM
joey_B's Avatar
Default check engine light not illuminating at startup
I have a 1998 accord V6 and the check engine light is not illuminating when starting the car. However, if I turn the key 1/2 way just to illuminate the dash without starting the engine the check engine light will light up. This shows me that the bulb is not burnt out. Any idea why the CEL will not light up when actually turning the car on?
Old Jan 16, 2015 | 02:30 PM
slomofo's Avatar
GDD Member
Default Re: check engine light not illuminating at startup
It's not supposed to stay on when you start the car, only when the key is on and engine is off.
Old Jan 16, 2015 | 02:41 PM
joey_B's Avatar
I understand that its not supposed to stay on. It doesn't come on at all when starting the car. However, I can tell that the bulb is not burnt out, because if I turn the key half way (without turning the engine) the bulb will illuminate). It should come on for ~2 seconds and then turn off if no issue is detected.
Old Jan 16, 2015 | 04:04 PM
slomofo's Avatar
GDD Member
I understand what you're saying, but I don't think you understand that I understand.
Understand?
Key on, engine off - CEL will illuminate for two seconds, then turn off.
Key on, engine off - CEL not suppoosed to illuminate.
Old Jan 16, 2015 | 04:32 PM
holmesnmanny's Avatar
It only comes one for a couple seconds when you turn the key on to let you know its checking for errors. Then it shuts off.
Old Dec 23, 2015 | 05:47 PM
fixauto4b's Avatar
on this topic, i have a 2000 Acura TL... Honda similarity. not starting on key turn. MIL/CEL never lights... nor does immobilizer key. i do have most other dash light coming on during key to on/start. i have been troubleshooting an ACG S fuse blowing and fuel pump never gets engaged, but realized that these lights never come on, so concerned their circuits are causing/contributing to no start.
any thoughts?
danuska17
Aug 1, 2017 07:19 PM
butter99
15
Dec 18, 2008 04:27 PM
jakscivic
May 14, 2005 01:49 PM
CTR_EK9
Feb 14, 2003 11:01 AM
