Burning smell after steep hill climb
Old Jan 14, 2015 | 12:02 PM
schererpr's Avatar
Default Burning smell after steep hill climb
My son's 98 civic EX has a strong burning, sort of a burned rubber smell after climbing the steep hill to our house (~400 ft vertical), and after ~ 1 hr. on the freeway. Going the other way, there is a slight smell when he gets to the parking garage on the other end of the trip. I replaced the engine about 20K ago, including brakes, motor mounts, belts hoses etc, and the only fluid leak is a very slow leak from the right axle connection with the AT ( used a cheap aftermarket axle from NAPA). The smell is recent, after about 6mo. on the new engine. We did not have this problem with the old engine. I have tried tightening the belts. Passed CA emissions right after engine replacement. Any ideas on what to check, and how
Old Jan 14, 2015 | 12:18 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Burning smell after steep hill climb
Do a compression test, and do a visual check to make sure those belts aren't rubbing against anything.
Nick Scroggins
Jan 3, 2018 06:42 AM
Eric Selfridge
Honda CR-V & Element
Nov 12, 2017 05:57 PM
Tremendus
Sep 9, 2013 07:34 AM
vtak2nr
Honda Civic (2001 - 2005)
Mar 25, 2012 05:42 PM
Jason kiDD
Oct 27, 2002 06:44 PM
