NSX calipers for ITR???
Old Nov 2, 2002 | 07:54 PM
TurboDANDEE's Avatar
Default NSX calipers for ITR???
I know its been covered so many times and i already did a search. But can anyone post some pics of them because the ones they have on the archives arent working. From what I read, i would need the ones from 91-96 NSX right? Is there any possible way I can use the 97+ ones because i can get a pair for $250 and i will be using the stock ITR rims. But if someone can get me a pair of the earlier ones, that would be great also. Well please help me out with this one and please dont flame. Thanx and peace out.
Old Nov 2, 2002 | 08:14 PM
MiraiZ's Avatar
Default Re: NSX calipers for ITR??? (TurboDANDEE)
it depends what size wheels you have...I think after a certain year the NSX wehnt for 15" to 16" (front wheels)...you'll have to figure out what year that was ...In Japan, the NSX has 16" and went 17" in 2002.
Anyways...the pics above is for 16"
Below are for 17"
Old Nov 2, 2002 | 08:34 PM
nsxtcjr's Avatar
New User
In 1994 the NSX went from 15" front wheels to 16" front wheels, but the calipers and the rest of the brakes stayed the same. In 1997 the size of the rotors increased from 282 mm front and rear to 298 mm front and 303 mm rear. The front calipers and bracket also changed, and one of the two pistons increased in diameter. I believe that the '97+ front NSX calipers will not fit under 15" wheels.
[Modified by nsxtcjr, 11:36 PM 11/2/2002]
Old Nov 2, 2002 | 09:55 PM
Default Re: NSX calipers for ITR??? (nsxtcjr)
so you're saying that i can still use the 97+ calipers but i will have to use 16" rims and will not fit the stock ITR wheels? Will the 97+ calipers bolt up like the 91-96 or is there special modifications i have to do to make it fit? thanx for the replies guys.
Old Nov 2, 2002 | 10:18 PM
DarthLuder's Avatar
New User
Migs, did a NSX caliper post awhile ago.
https://honda-tech.com/zerothread?id=239844
[Modified by ITR GURU, 7:31 AM 11/3/2002]
Old Nov 2, 2002 | 10:45 PM
Default Re: NSX calipers for ITR??? (ITR GURU)
thanx man, i saw that already. But i believe he's using the earlier model NSX calipers and the pics arent working, i need info on the newer ones 97+ because thats the one i can get my hands on. If anyone know where i can find the 91-96 calipers, that would be great.
Old Nov 3, 2002 | 04:02 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
hey, what year is the zanardi edition nsx? my calipers should be here soon. i know these bolted on, with no issues on yasu's 98 itr.
Old Nov 3, 2002 | 04:12 AM
B( * Y * )BIES's Avatar
The easiest NSX calipers to use would be the 91-96's. For the 97+ the front caliper is lager as is the rotor. Yes, it is possible for you to use the 97+ ones but you will need 16" rims and proper mounting hardware. There's a place in NY that is kind of like a NSX junk yard... don't recall their name - I <u>think</u> it was EZR or ERZ with either "auto" or "cars" following the name.
Sorry i don't have any pix handy.
Best of luck - I'm looking to do the NSX brake upgrade also.
Old Nov 3, 2002 | 06:49 AM
nsxtcjr's Avatar
New User
Default Re: NSX calipers for ITR??? (rodney)
'99, and it uses the same calipers as other '99 NSXs.
There's a place in NY that is kind of like a NSX junk yard... don't recall their name - I think it was EZR or ERZ with either "auto" or "cars" following the name.
You're referring to this place.
Old Nov 3, 2002 | 06:56 AM
Dropspeed's Avatar
I have a set of 91+ NSX calipers at the powder coaters now, Once they are done and rebuild I'll try and document my installation.
Mattj
Old Nov 3, 2002 | 07:48 AM
migs's Avatar
Default Re: NSX calipers for ITR??? (Dropspeed)
Well, here are the pictures Im sure you guys might be looking for. Sorry if it was overkill and some pictures are blurry.
Id have to say after 4 months of use. Ive NEVER (yes, NEVER) experienced brake fade. I would have to say Im completely satisfied with the setup.
Let me know if you have any questions on the pictures. They should kind of explain itself.
--migs
Old Nov 3, 2002 | 07:49 AM
migs's Avatar
Turbo, are you sourcing these calipers through a guy in Houston?
Old Nov 3, 2002 | 10:08 AM
Default Re: NSX calipers for ITR??? (Migs)
Yes i am. I met this guy named Brad that has a black NSX and he had some Brembo brakes on his car. I asked him about his old calipers and he said he would sell it to me. I forgot to ask what year his car was but im pretty sure it's 97+ because he had the gunmetal NSX rims.
MIGS: would you happen to know where i can get some 91-96 calipers?
[Modified by TurboDANDEE, 1:15 PM 11/3/2002]
Old Nov 3, 2002 | 10:37 AM
Petah's Avatar
So any 91 - 96 NSX calipers will bolt onto a ITR? But what rotors will you be using?
Old Nov 3, 2002 | 12:10 PM
migs's Avatar
Default Re: NSX calipers for ITR??? (eg-six)
TurboDANDEE: I have a few sources that I can try checking with on Monday and Ill let you know just as soon as I find out. If I dont get back to you, just drop me a line.
EGSIX: You can use either ITR rotors or Legend rotors. Using 91-96 NSX calipers with ITR rotors require you to buy (4) NSX brake caliper mounting bolts which are roughly 4-5/piece from the dealership. Ask "REID" on the part number, I know he can help you out.
--migs
Old Nov 3, 2002 | 12:17 PM
Reid's Avatar
Global Moderator
Part # is 90107-SL0-000 and cost should be ~$3.
Old Nov 3, 2002 | 01:29 PM
nsxtcjr's Avatar
New User
Maybe not.
In 1994-96, the NSX rims were Solaris Silver, which is a gunmetal color virtually identical to the ITR gunmetal rims. In 1997, NSX rims changed to Blades Silver, which looks like a clearcoated, satin-polished metal.
Old Nov 3, 2002 | 01:35 PM
MIGS: Thanx for looking it up for me. Let me know what u find out and how much. Ill give u a line if I dont hear from you sometime next week.
Old Nov 3, 2002 | 02:23 PM
Petah's Avatar
--migs
So if i use ITR rotors with NSX bolts, will i still need washers to space out the caliper brackets? If so, how much thick (of a washer) do i have to use?
What about using legend rotors? Would i need to use washers again to space out the caliper bracket? If so, how much??
Thanks!
Old Nov 3, 2002 | 02:24 PM
Petah's Avatar
Default Re: NSX calipers for ITR??? (Reid)
Thanks for the info...i will be looking into this mod......thanks again for the good info!
Old Nov 3, 2002 | 03:53 PM
migs's Avatar
--migs
Thanks!
NSX calipers with:
ITR 23mm rotors: need (4) NSX brake caliper mounting bolts w/ 4-5mm shimming (washers) PER bolt.
Legend 28mm rotors: can use your stock ITR brake caliper mounting bolts w/ 2mm shimming
Old Nov 3, 2002 | 08:13 PM
Variance's Avatar
Are there advantages in using the larger legend rotors?
Old Nov 3, 2002 | 08:15 PM
Reid's Avatar
Global Moderator
Default Re: NSX calipers for ITR??? (HachiSix)
More thermal mass.
But also more unsprung weight.
Old Nov 3, 2002 | 08:55 PM
555R's Avatar
does anyone have closeup shots of the stock ITR calipers and stock wheels for comparison
ex- how close to the spokes the actually come
ex- ITR calipers, Spoon calipers and NSX calipers
thanks
Old Nov 3, 2002 | 09:07 PM
migs's Avatar
Default Re: NSX calipers for ITR??? (555R)
thanks
Here is a closeup of the 2 calipers.
