1995 Honda Accord, Will not start in the cold
Hey guys,
So first the basics:
1995 Honda Accord, LX, 2.2L 4 cyl engine, standard transmission, 240,000 km (150,000 miles for you 'mericans)
I'm from the BC coast where the winters are usually never much below freezing, and my car has performed fine for the past year. I've recently started working in Saskatchewan, where its consistently between -15 and -30 celsius (5 to -22 f).
Things I've done recently:
-oil change (low viscosity 5w30)
-brand new battery (highest cold cranking amps they had, 825)
-put de-icer in gas tank (basically methanol to clean lines)
-added a battery warmer and a block heater that run all night. The block heater is really just a large electric heater thats stick to the bottom of my oil pan via a magnet.
I've been having some issues starting my car in the cold. If its above 5 degrees (41 f) zero issues starting, as it drops towards -5 degrees (23 f), it usually takes around five mins to start. Once it's real cold, say anything below -15 (5 f) its a b*tch to start, and more often than not it doesn't. I made a video showing what happens when I try to start it. Funny enough I'd read online that it could be an engine temp sensor thats busted, and pumping the gas might help it start. Mind you I'd tried this quite a lot before, it just happened to work this time in the video, it seems that usually it doesn't hemp to push the gas, before or during starting.
https://www.dropbox.com/s/0xii56b4jr...%20PM.mov?dl=0
Trying to start my car, it's -20 C (-4 f). Sorry for the potato quality video and my mumbling.
When I stick my key in the ignition and turn it to just before where it would turn over, I can hear the fuel pump warm up and all the electrics work. When I try to turn the car over theres just a quiet humming sound, I can also hear the relay click as I try to start it. I can't seem to figure out what's wrong, maybe its the starter?
If you guys can help me I'd REALLY appreciate it. I'll be checking back as often as possible, so if you need more info just yell at me and I'll try to reply asap. Thanks.
Pictures of the dash in the accessories position (-20 c/-4 f):
https://secure.flickr.com/photos/873...57650236074005
https://secure.flickr.com/photos/873...7650236074005/
Test the two prong sensor under the distributor for ohms across the two pins with the car cold and tell us what you get. It should be around 2500 ohms or so or a lil bit more. Remember to test it at around the temp you have issues at, then warm the car up fully and test it again. Let us know your two values.
Hey thanks. I'll see if I can find a multimeter tom morn (I may not be able to get my hands on one). Are you referring to the sensor just below and in front of the distributor (seems like the one), or one of the two that sit behind it?
Pic of sensor in front:
Top view of sensors in behind distributor:
Not the green one... and that one isnt below the distributor .. looking past it, there is one that is a single connector, there should be one next to it, you want that one.
Also you need another valve cover gasket and distributor oring.
HondaDadi
11
Jun 18, 2019 04:55 AM
darthvader747
May 18, 2017 01:33 AM
gerhard
Dec 7, 2007 03:00 PM
